Thread: cruise control problem- how to diagnose?
Results 1 to 4 of 4
  1. #1 cruise control problem- how to diagnose?
    Donating Users
    Aug 2013
    Michigan, USA
    I think I have a bad switch in the steering wheel but I need to check before I pay someone to take the wheel apart (I don't want to mess around next to air bags). The cruise sometimes set when I press it (shows on DIC), sometimes it sets then cancels right away like I pressed down and pulled toward cancel. Other times it just won't do anything. Resume has never worked for me.
    Since it sometimes worked, I'm pretty sure the problem is at the steering wheel switch. What can I do to find out for sure? And is there a source of new switch, like at AutoZone or such?
    GP 04+, NA, base
  2. #2 Re: cruise control problem- how to diagnose?
    Feb 2013
    Missouri
    Sounds like it might be a brake switch issue. Has anything ever been done with the brake pedal position sensor? I'd start there.
  3. #3 Re: cruise control problem- how to diagnose?
    Donating Users
    Aug 2013
    Michigan, USA
    Nothing had been done to the brakes since I got the car. The switch is under the dash along the brake pedal arm right? Or is there another switch? I can check when it's light outside (3:15 AM here now) with my multimeter. Is it a simple on/off switch or a variable resistor like?
  4. #4 Re: cruise control problem- how to diagnose?
    Feb 2013
    Missouri
    I think it's variable, according to this site:
    http://www.grandprixforums.net/servi...ree-81286.html
    Seems different than the typical on\off switch that 97-03 and most cruise control setups have.
  1. Help me diagnose my trans problem
    By Zinergy in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-21-2012, 03:48 PM
  2. ABS, traction control light and no cruise control?
    By dirtdriver11 in forum General Tech Discussion
    Last Post: 07-30-2012, 07:16 AM
  3. Traction control, ABS and Cruise control dont work
    By Adamcc91 in forum Brakes/Suspension/Chassis
    Last Post: 02-04-2011, 05:07 PM
  4. Diagnose my problem please
    By skeelo58 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-19-2010, 12:21 AM
  5. Cruise Control problem.
    By jordyfallacy in forum General Tech Discussion
    Last Post: 03-08-2010, 11:32 PM
