Thread: Water in floor board
Results 1 to 16 of 16
  1. #1 Water in floor board
    SE Level Member Catalyst's Avatar
    Apr 2013
    Arkansas
    OK, so I took my interior out to do some work and I notice the passenger floor board was wet. I let it set for a few days, and it had not rained in about a week here. I picked it up from a friends house, where it was while I was out of town. I drove it to work this morning, about a 30 min drive from his house. when i got to work there was water in the floor board again, like I said it hadn't rained in a week. Where could that water come from, it was dry when I started driving. The A/C was on, not sure if that would cause it. I searched here, and I moslty found where it was wet AFTER it rained. Any input would be appreciated.
    1998 GTP Coupe | Flowmaster Exhaust | ZZP Downpipe | ZZP 1.0 PCM | Front/Rear Strut Bars | 180* T-Stat |
  2. #2 Re: Water in floor board
  3. #3 Re: Water in floor board
    Feb 2013
    37.295091, -121.930053
    wow that was fast lol and welcome to GPF lets see them sexy pictures
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  4. #4 Re: Water in floor board
    SE Level Member buford1972's Avatar
    Apr 2009
    Peoria, Arizona
    My personal experiance is that the water was coming in from the wiper cowel on the passenger side. The rain runs down the windshield, goes past the cheep and prob by this point worn out weatherstrip gasket on the plastic cowel cover, runs down past the heater/AC blower motor fan blades, drips onto the passenger side floor, then collects behind the front passenger seat. You can get an updated water deflector from the dealer that sits below the plastic wiper cowel and above the fresh air intake (where a cabin air filter would go if you have done this mod on your GP or own a Monte or Buick since it is stock on most of them). It tucks under the windshield a bit and is much longer that the air intake opening. The GM part # is 12591982 and is labled as a "shield". Mine cost me $9.14 after tax. I had about 3 gallons of water in mine from sitting for a week while it rained everyday. This resulted in pulling the seats and carpet out to allow things to dry. On the flip side I used this time to line my entire floor and interior with Dexdamp sound deadener. Hope this helps.
    Comp Cams Cam. #150 springs. roller rockers. CNC heads. 3.4" pulley. P&P Gen V. 8-rib w/belt wrap. N* & LQ4. 1" phenolic spacer. P&P/coated LIM. boost temp gauge. Aeromotive fuel rails. underdrive W/P pulley. coated TOG headers. Magnaflow cat back. Random Tech DP & Cat. balance shaft delete. built trans. Hughes converter.
  5. #5 Re: Water in floor board
    Apr 2013
    Arkansas
    I have read that post. Didnt think that would apply to me, because the water appeared a week after it rained. I will still try that though, thanks for the info.
    Is that fix for a 97-03 or 04+
  6. #6 Re: Water in floor board
    GT Level Member WolvesSoulZ's Avatar
    Québec
    Both generations.
    2000 GT - L67 swapped SOLD | 2004 GT1 - Winter Beater - SOLD
    2004 GTP Comp-G - 3.3"/3.2", XP, #50 , 4" MAF, SD's, 180*, AL103's, HAI, Tuned, 06+ Dual pistons brakes, STB's, SSC's and FE3.
    2011 Audi A6 S-Line - Also Supercharged
  7. #7 Re: Water in floor board
    Nov 2012
    Madison
    Are you sure it's not coolant?
  8. #8 Re: Water in floor board
    Apr 2013
    Arkansas
    Quote Originally Posted by spazzz View Post
    That's the first thing I checked, its water for sure. I'm thinking its something to do with the A/C. Maybe its draining into the car or something. Gonna dry it out and drive with no A/C on, and see if it appears again.
  9. #9 Re: Water in floor board
    mi
    You already got the answer, a/c not draining correctly
    Sent from my SPH-D710 using Tapatalk 2
  10. #10 Re: Water in floor board
    Apr 2013
    Arkansas
    Quote Originally Posted by siLversLeigh View Post
    Anyone know how to fix that?
  11. #11 Re: Water in floor board
    Sep 2011
    Copperas Cove, TEXAS
    Quote Originally Posted by Catalyst View Post
    Find the A/C drain tube and stick a coat hanger or whatever up in it to clear the blockage. If that don't work check to make sure the drain tube did not disconnect fron the unit, if so, you might have to pull the A/C unit from behind the dash.
  12. #12 Re: Water in floor board
    Apr 2013
    Arkansas
    Just to make sure I have the right thing....
    Is this the A/C drain, with the brown 90*?
  13. #13 Re: Water in floor board
    the drain is on the fire wall, at the bottom, out side, engine bay side.
  14. #14 Re: Water in floor board
    Apr 2013
    Arkansas
    Thank you. I found it.
    So I started the car and turned the air on full blast. Waited for it to start running in the floor, only it never did. I looked under the car and saw it was draining to the ground. I decided to take a drive and see what happens. I drove around for about 10-20 min and it started to drain into the floor again. I got back home and found it is draining into the car right wear it goes through the firewall, on the inside of the car, behind all the foam and stuff. Any one have any ideas on how to remedy this? Thanks.
  15. #15 Re: Water in floor board
    Nov 2012
    Madison
    A/C might drain at first until it starts really cranking. It sounds as if it is still plugged.
    Did you see this,>>> if not check it out. DIY: A/C Evaporator drain plug un-clog (no tools required!) - Monte Carlo Forum - Monte Carlo Enthusiast Forums
  16. #16 Re: Water in floor board
    Apr 2013
    Arkansas
    Thank you for the link, it shed some light on it. I did notice in the pictures that, I think, I am missing the 90* elbow that attaches to the hose at the firewall. All I see on my car is a small hole in the liner stuff on the fire wall. It looks to be a little bit recessed into the firewall, there is no excess sticking out, and no elbow.
  1. Wet passenger floor board in 2003 Pontiac Grand Prix
    By Shawn O in forum Introductions/Noob Questions
    Last Post: 07-19-2013, 02:56 PM
  2. Water on passanger floor board.
    By selym17 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-04-2012, 10:44 PM
  3. water on floor board
    By flower50 in forum Introductions/Noob Questions
    Last Post: 06-16-2010, 12:35 PM
  4. water in heater blower fan or water on passanger floor
    By coolcat2010 in forum How To Write-Ups/Tech Tips
    Last Post: 03-19-2010, 04:20 PM
  5. Water in floor board brought me here. THANK GOD!!
    By eddieb in forum Introductions/Noob Questions
    Last Post: 04-13-2009, 06:21 PM
