Thread: maf sensor
Results 1 to 8 of 8
  1. #1 maf sensor
    Jun 2012
    baltimore
    ok i know where the mass air flow sensor in in area but there are 3 sensors there which one is it? i wanted to take it off before i got the new one since there is a core charge. i am just not sure which sensor is the mass air flow. also if it is the ones with the screw that appear to be torx with a piece in the middle is that a special kind of torx bit?
    thanks guys
  2. #2 Re: maf sensor
    St. Louis
    Yes, it is the one with the safety/security torx. It's the black module that mounts to the top of the throttle body. Click on the pic for a larger view.
  3. #3 Re: maf sensor
    Jun 2012
    baltimore
    so how do i get it off i only have standard torx. can i buy a set that has a hole in the end of the bit?
  4. #4 Re: maf sensor
    you can buy the bits or use a hack saw or dremell to cut a straight line across the screw head, then use a flat head screw driver.
  5. #5 Re: maf sensor
    Jun 2012
    baltimore
    thanks guys. as usual you guys help me out
  6. #6 Re: maf sensor
    Dec 2012
    Where 4T65E's were born
    If you want the correct tool, this is what I bought and has a good set of security torx in it. I've used it to take my MAF off once.
    Performance Tool W1384 - Security Bit Set | O'Reilly Auto Parts
    Sold.
  7. #7 Re: maf sensor
    St. Louis
    If you don't have the dremel or a hacksaw, or the funds to get the correct bit set I have in the past been able to get the edge of small cold chisel (or a flat screwdriver you don't care about) on the post in the middle of the torx bolt and gently pop it bending it to one side. Don't beat it like it owes you money, just a few taps from a hammer and it should bend enough to be grabbed with a pair of needle nose pliers, worked back and forth and popped off. Then just use a standard torx bit to remove it.
    I take no responsibility for a bad MAF, lol.... just sayin.
  8. #8 Re: maf sensor
    Donating Users
    Aug 2013
    Michigan, USA
    Some decent hardware store carries multi bits kit that has close to 40 different size and types of security bits. Works with standard 1/4" driver. I have a couple of them (one is always missing when I needed it but with 2, one's always around when I need it )
  1. 0 KR rear sensor & 5-7 degrees KR front sensor
    By Elite6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-09-2013, 08:06 PM
  2. O2 Sensor not working... P0171 new sensor still no data from O2?
    By Z34Phoenix in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-16-2012, 12:20 PM
  3. question about low coolant sensor,fuel level sensor,and the
    By spider4 in forum General Tech Discussion
    Last Post: 11-26-2011, 09:19 AM
  4. camshaft sensor or crank sensor?
    By Viper in forum 3.1L V6 (LHO/LG8)
    Last Post: 09-06-2010, 04:43 PM
  5. Picture request of Coolant Temp Sensor and TPS sensor parts
    By David A Smith in forum Shops and Community Heroes
    Last Post: 06-11-2010, 11:05 AM
