I have a 97 grandprix gt 3800,when i try to start it , it takes 2 to 3 tries before it will start. i've run a fuel pressure test ,as soon as the ig switch is turned on it shows 50 to55 lbs pressure ,30 seconds after i turn the ig switch off the pressure drops to 0.what else should i check. thanks clifweb
