Thread: Brake and back up lights dim on drivers saide
Results 1 to 6 of 6
  1. #1 Brake and back up lights dim on drivers saide
    GTP Level Member Burbman's Avatar
    Dec 2008
    ****'s Creek
    Hi guys, 2001 GT. Thought my drivers side brake light was out so stopped at Advance for a bulb. Bulb lights but only half as bright as passenger side. Same thing with back up bulb, comes on in reverse but only half as bright as right side. I'm thinking bad ground, anybody know where it is offhand before I start digging in?
  2. #2 Re: Brake and back up lights dim on drivers saide
    GTP Level Member LeadfootCJ7's Avatar
    Oct 2012
    Houston, TX
    I would start with checking grounds and connectors.
    2007 Grand Prix GXP;2002 Camaro Z28 - tune, CAI, and exhaust
    2006 GMC 2500HD - ATS high flow manifolds and uppipes, turbo back exhaust, blocked EGR, Denali headlights, Reflexxion Cown Hood
    1994 Olds Cutlass Supreme 2 door
  3. #3 Re: Brake and back up lights dim on drivers saide
    Donating Users
    Aug 2013
    Michigan, USA
    Probe it with volt meter. Could be dirty socket, bad ground connection, or partially broken wiring.
  4. #4 Re: Brake and back up lights dim on drivers saide
    St. Louis
    Do you have condensation inside that taillight? If so I'd bet the bulb sockets are all corroded. Happened on my 00GT. Replaced the taillight assembly with a good one and clean up the bulb sockets and all is well. They were not only wet, but very green with corrosion.
  5. #5 Re: Brake and back up lights dim on drivers saide
    SWPA
    Dim bulbs definitely sounds like a poor ground situation. I have had the issue myself on other cars in the past.
  6. #6 Re: Brake and back up lights dim on drivers saide
    Dec 2008
    ****'s Creek
    Anybody know offhand where that harness grounds at? The wire loom heads across to the right side running behind the bumper cover....
  1. Replies: 2
    Last Post: 12-19-2012, 01:43 PM
  2. Help REAR TAIL LIGHTS NOT WORKING, BUT BRAKE LIGHTS WORK.
    By shihiran in forum General Tech Discussion
    Last Post: 10-21-2012, 02:35 PM
  3. back brake piston stuck
    By Lionel in forum Brakes/Suspension/Chassis
    Last Post: 05-29-2010, 06:41 PM
  4. Interior lights wont come on, drivers door 98 GTP
    By boostedzx3 in forum General Tech Discussion
    Last Post: 03-25-2010, 12:05 PM
