Thread: Digital Climate Control issues...
Results 1 to 7 of 7
  1. #1 Digital Climate Control issues...
    Feb 2013
    Missouri
    Hey everyone,
    My GTP has the digital climate control, but it is having a problem with the driver side blend door. I have pulled the actuator, tried it on the passenger side, and it works great. Just to see, I put the passenger side on the driver side, and it had the same behavior as the original. I disconnected the battery to perform the "relearn" of the actuators, and they both move fully like they should during the relearn. When I change the temperature on the driver side nothing happens, but the passenger side works flawlessly. I also go into diagnostic mode on the climate control and it is showing a system pass code (00 in the -00 menu). I'm pretty much at a loss as to what to check next, what would you guys recommend?
    Thanks in advance.
  2. #2 Re: Digital Climate Control issues...
    Aug 2013
    Goshen, Ohio
    What controls the climate control? Is it like the older Chevy trucks where the actual HVAC controls on the dash does everything? There is no BCM until the mid 2000's right? I would go hit a pull and pay junkyard and get set of controls.
  3. #3 Re: Digital Climate Control issues...
    Feb 2013
    Missouri
    I found this on youtube, It's the same model number as what I have(CJ2), but in a different GM vehicle. Looks like there is quite a bit involved...
    Buick - CJ2 Automatic HVAC Systems (1999) - YouTube
  4. #4 Re: Digital Climate Control issues...
    Aug 2013
    Goshen, Ohio
    Mine doesnt get as cold on the driver's side as the passenger's.
  5. #5 Re: Digital Climate Control issues...
    Feb 2013
    Missouri
    Mine stays cold, or at least stays "neutral" It's been cool for a few days here so the A\C doesn't make much of a difference, but the passenger side gets nice and hot while the driver is normal, not hot, not cold.
  6. #6 Re: Digital Climate Control issues...
    GTP Level Member Burbman's Avatar
    Dec 2008
    ****'s Creek
    Good grief that is complicated
  7. #7 Re: Digital Climate Control issues...
    Feb 2013
    Missouri
    I was looking at the schematic for it all and it looks like there's only a few wires that run from the control module to the actuators. I'll just take voltage samples from the passenger side then compare it to the driver side and go from there. I think it's the module, I had planned on replacing it anyways because of the buttons being worn through, so I hope it is the module. Previously I was worried it could be a sensor or something of the sorts, but it appears that both driver and passenger side share a lot of the same sensors. Here's the schematic:
  1. Digital Climate Control
    By PurpleGuy in forum General Tech Discussion
    Last Post: 04-09-2013, 11:46 AM
  2. Digital climate control
    By phil morris in forum Introductions/Noob Questions
    Last Post: 05-16-2012, 03:54 PM
  3. Digital Driver Information Center and Digital Climate Control
    By uNda6gT in forum Visual/Body Modifications
    Last Post: 03-28-2012, 10:47 PM
  4. Digital climate control
    By GTP2188 in forum General Tech Discussion
    Last Post: 09-14-2011, 01:34 PM
  5. Digital CLimate control
    By jacobmh27 in forum Visual/Body Modifications
    Last Post: 10-15-2009, 08:01 AM
