Thread: Is this the Dorman Sway bar?
Results 1 to 11 of 11
  1. #1 Is this the Dorman Sway bar?
    Jan 2012
    N/A
    Grand Prix Sway Bar Link Is this the dorman sway bar?
  2. #2 Re: Is this the Dorman Sway bar?
    Ocala, FL
    It's likely either a dorman or a GMPP.
    The sticker on it actually makes me think GMPP. Unless Dorman's come with one there as well, I'm not sure.
  3. #3 Re: Is this the Dorman Sway bar?
    Jan 2012
    N/A
    Im debating if I should pick this up, and buy a rear later, or just wait and get the kit off gmpartsdirect
  4. #4 Re: Is this the Dorman Sway bar?
    GTX Level Member SomeDudeAtHome's Avatar
    Buffalo, NY
    The doorman one i bought had a sticker that said Passenger on it and a white stamp with their name on it. For $50 though you might as well buy a new one for an extra $25 and know what you're getting.
    Black 98 GT bought in summer of 2009 w/28K miles- GTX Rims, Retrofit headlights, tinted tails, 20% tint all around, KYB Excel-G's, WBS Lowering Springs, 33mm Dorman front sway bar, 22mm Addco rear sway bar, BMR trailing arms, BMR STBs front and rear, ZZP control arms, Poly motor mounts, ZZP CAI, Thrasher shift kit
  5. #5 Re: Is this the Dorman Sway bar?
    May 2012
    Albuquerque, NM
    Does that GMPP make a noticeable difference? I'm thinking of getting it but can't find many reviews. Thoughts?
  6. #6 Re: Is this the Dorman Sway bar?
    Buffalo, NY
    I just did both my front and rears yesterday and it made a huge difference. I didn't use the GMPP so can't really speak about that or doing the front alone but I'd say it's worth it. I'd go with something different than the GMPP though because the front is hollow. The ZZP Progress front is the same diameter and solid for $150 or the Doorman is a millimeter smaller, solid and only $80.
  7. #7 Re: Is this the Dorman Sway bar?
    GT Level Member addzradd's Avatar
    Feb 2010
    Cleveland
    Soild swaybars are stupid, they are much heavier and are not any stiffer. But yeah if I was upgrading I would start in the back first.
  8. #8 Re: Is this the Dorman Sway bar?
    Pennsylvania, USA
    Quote Originally Posted by addzradd View Post
    The benefit of solid bars is knowing it won't rot through and snap on the end, and it only adds a few pounds. Good for people in the rust belt.
    Just get a new Dorman off Amazon, they're cheap as hell on there.
    I'd suggest poly bushings and end links too, they make a big difference and won't rot out in a year like mine did, the included bushings are made of crap rubber. Or it's just due to PA winters, who knows.
  9. #9 Re: Is this the Dorman Sway bar?
    Buffalo, NY
    I agree with what nik said about this. Solid bars aren't stupid for people where rust is a problem. And the weight they add is so little that unless your making a drag car who cares.
  10. #10 Re: Is this the Dorman Sway bar?
    Quote Originally Posted by nik12937 View Post
    its got nothing to do with winter, they are flat out crap bushing that dorman sells with their sway bar. the end links are ok, its the bar bushings that fall apart in a year or less, and ive got maybe 5,000 miles on then, still fell apart and now clunk on one side.
    get the polly bushings, why change them later like i will have to now.
  11. #11 Re: Is this the Dorman Sway bar?
    Buffalo, NY
    ^^^ I agree that the bushings are horrible that come with them and to go with poly right from the start but winters/salt do take a toll on hollow bars. Check out my suspension thread. The stock hollow one I pulled off my car (only 55K) was cracked on both ends where it connects to the endlinks. A solid bar won't have that problem.
  1. Sway bar 33mm vs 30 mm - Dorman - will the 33mm work on my car?
    By GT2001Aurora in forum Brakes/Suspension/Chassis
    Last Post: 04-13-2013, 10:09 AM
  2. Dorman Fornt Sway Bar Squeaks
    By Joe942 in forum Brakes/Suspension/Chassis
    Last Post: 09-22-2011, 07:06 AM
  3. Dorman Intake
    By GMFI in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-28-2009, 01:11 AM
