Assuming from your profile picture you have an 04+, remove fuse panel
Pull off the floor board cover under dash there should be too plastic pins you can use a flat head screw driver to pry them out
Then pull the plastic dash peice off
open glove box there's this black plastic part grab like so and push it to the left
Now unscrew the 4 screws on the glove box then done, it's really easy honestly
