Thread: ABS, Trac, and tight steering on a 2000 GTX
Results 1 to 4 of 4
  1. #1 ABS, Trac, and tight steering on a 2000 GTX
    Jan 2013
    Gainesville, Fl
    I have a 2000 Grand Prix GTX and I am having an issue with the ABS and Trac light coming on every now and then. When it comes on the steering gets tight. I recently replaced 2 front bearings about 3 weeks ago. A week after I replaced them I noticed the issue. I haven't been able to read a code on it yet. Does anyone have an idea of what is happening? I read up on a couple things and people are saying ECM, wiring harness issue, and speed sensor. I just think it is weird that my steering gets tight when these lights pop on.
    Thanks,
    Josh
  2. #2 Re: ABS, Trac, and tight steering on a 2000 GTX
    Magnasteer.
    When the ABS light comes on, your magnasteer stops working.
  3. #3 Re: ABS, Trac, and tight steering on a 2000 GTX
    when my abs light comes on the steering also gets tight. its normal.
    i also have yet to scan the abs light, replaced 2 front hubs, and the abs module as well, tends to fail the self test at first start up. once in a blue moon.
  4. #4 Re: ABS, Trac, and tight steering on a 2000 GTX
    Pennsylvania, USA
    I'd look at the wiring that goes to the hubs, one of mine had like, a hair of wire exposed under the insulation and I got all those lights and tight steering randomly.
    I just cut out the exposed chunk, soldered in a new piece and used liquid electrical tape and heat shrink tubing to seal it off. No problems since.
  1. 2000 Grand Prix Tachometer/Trac Light/Stall Issues
    By ZackN in forum General Tech Discussion
    Last Post: 09-26-2013, 11:40 AM
  2. ABS & Trac light on, harder to turn steering wheel
    By GTLGDP in forum General Tech Discussion
    Last Post: 09-06-2012, 02:04 PM
  3. a/c abs light and tight steering ..need help
    By The Wolf in forum General Tech Discussion
    Last Post: 09-05-2011, 07:05 PM
  4. Hi im a newbie (2000 3.1 trac control and govener prob)
    By thegreenmachine in forum Introductions/Noob Questions
    Last Post: 01-09-2011, 12:19 PM
  5. tight ride
    By black betty in forum Introductions/Noob Questions
    Last Post: 02-09-2010, 09:11 AM
