Thread: What is needed to change final drive ratio?
Results 1 to 5 of 5
  1. #1 What is needed to change final drive ratio?
    Jun 2013
    Hollywood ,FL
    might have to look into this mod next a higher final drive besides having to tune your pcm for higher final drive is thee anything else required?
  2. #2 Re: What is needed to change final drive ratio?
    You could pull the transmission
    http://www.grandprixforums.net/how-r...ion-35485.html
    Then remove the side cover, valve body/channel plate as a combo, remove input shaft o-ring then you can lift up the chain/gears. and change the gears. The link below shows how to do most of this, and suggests the 4th hub (03 or below should consider doing this automatically)
    http://www.grandprixforums.net/how-t...ess-54448.html
    Then you need to program it. Here are the HPT instructions
    http://www.grandprixforums.net/how-p...hpt-75323.html
  3. #3 Re: What is needed to change final drive ratio?
    Jun 2013
    Hollywood ,FL
    think ill pay someone to do that you think any tranny shop will be able to install the final drive if I provide it? what do you think is rough estimate on labor
  4. #4 Re: What is needed to change final drive ratio?
    I'm sure they could do it, but not sure what they would charge for something like that.
    But you'll have to have it towed home or tuned on the spot to run right. A trans shop wont be able to custom tune the car.
  5. #5 Re: What is needed to change final drive ratio?
    You are talking about pulling a trans out. That's often $500 plus in labor alone.
  1. How to install final drive?
    By chapmanrandall in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-10-2011, 07:14 AM
  2. Final Drive Misinformation?
    By Confusingboat in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-24-2011, 10:30 PM
  3. What will my final drive ratio be?
    By DanGTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-02-2010, 01:09 AM
  4. Final drive ratio question
    By 07CrimsonGT in forum General Tech Discussion
    Last Post: 08-11-2009, 05:58 PM
