I want to get a 3 inch bolt it DP with Cat from ZZP. Then I plan on getting Magnaflow mufflers. And ideas anyone? Does the DP sound like a good idea. Idk if I should get a Shorty
a shorty you'd have to do some welding.
skip the cat if you can get someone to tune out the code.
the exhaust sounds like **** whatever you do, keep the stock mufflers.
if they tune the code out you will pass
why not just get a 3 inch dp with a cat?
just get one dont go for the stainless no benefits. and get the pre paid label in option 2. you send back your stock dp and they will give you a $50 coupon
it wont throw codes if it has a cat. and yes once you install your old one out ship it back
nope
Or you could do what they have convinced me to do. I was looking at the same downpipe with cat but I found speed daddy headers with a downpipe for only 220 shipped to door.
offer them 200 they will take it. but then also get a high flow cat for like 70ish dollars along with a o2 extension and double walled flex pipe if you go that route
or you can cut your current one out and weld that in
that goes for almost every set of headers
