Thread: Mods for my 98 GTP
Page 8 of 10 FirstFirst ... 678910 LastLast
Results 141 to 160 of 182
  1. #141 Re: Mods for my 98 GTP
    SE Level Member ngj123's Avatar
    Jun 2010
    Michigan
    I already have a quality tune from Intense, a cold air intake that I made and colder iridium spark plugs.
    Quote Originally Posted by 2FASTGTP View Post
    But still, think about it. You can get a ZZP downpipe for 150 if you send your old cat in and get $50 back. Install yourself, that saves you $700 to do other stuff to your car! A quality tune, CAI, spark plugs, anything! If your set on headers, go for it
  2. #142 Re: Mods for my 98 GTP
    GT Level Member 2FASTGTP's Avatar
    Apr 2012
    Indiana
    Quote Originally Posted by ngj123 View Post
    I just don't understand what a downpipe has to do with anything except for it being a little less restrictive. I mean headers should be way better than just throwing on a downpipe.
    Headers: probably 3.4" pulley
    Downpipe: probably 3.5" pulley
    All depends on your situation but it boils down to, is the extra gain from headers worth an additional $700?
  3. #143 Re: Mods for my 98 GTP
    8 pages this cannot be a serious thread............
  4. #144 Re: Mods for my 98 GTP
    Apr 2012
    Indiana
    Quote Originally Posted by 98GrandPrixIraqVet View Post
    It's veered of topic a little bit haha
  5. #145 Re: Mods for my 98 GTP
    GT Level Member JaredR215's Avatar
    Jul 2011
    Cheyenne
    This turned into another headers vs. Downpipe thread. Find a way to scan your car. Don't make assumptions on what you can run. Every car is different. Pulley envy seems at it's highest in here.
    K&N Cold Air, ZZP Wires, ZZP 3" with hi-flo, Catback, ZZP 1.0 PCM., 180*, AL605's, 3.5 MPSStill fighting KR
  6. #146 Re: Mods for my 98 GTP
    Pulley envy = blown engine
    Check around here you'll find several cases where guys would be so eager to pulley down and end up blowing their s**t up and then want to switch platforms.
    Just because one guy can get away running a 3.4 for example doesn't mean another guy can with the same mods. Elevation plays a huge part. As well as how the motor runs. Only thing that can be done is to scan scan scan for knock and make sure timing, a/f is set where you want and then decide of you want to go further.
    04 Comp G.
  7. #147 Re: Mods for my 98 GTP
    Guessing this is a mail order tune? Hate to break it to you but a mail order tune can only do so much. A in car tune can adjust the tune to your car not just some generic **** that some guy put together because it worked on another car.
    04 Comp G.
  8. #148 Re: Mods for my 98 GTP
    GXP Level Member Grimsin's Avatar
    St Thomas Ontario
    this thread is lols, headers is way more flow then just a downpipe, the front manifold is very restrictive, the rear one not so much. but if your only mildly modding then downpipe is the way to go.
    ngj123: are you paying $850 for just the install? you still have to buy their headers? cause if so thats ridicolouse...
    3.8l N/A POWA! :4'' HAI\L67 HVTB\HV3\ER Rockers\WP underdrive pulley\Headers\cat delete\91 octane overkill incar tune.3.69 gears, Trans go shift kit.
    My Car:http://www.grandprixforums.net/threa...2005-Impala-LS
  9. #149 Re: Mods for my 98 GTP
    Apr 2012
    Indiana
    Quote Originally Posted by Grimsin View Post
    So would a PLOG, u bend delete, straight 3" pipe and a glasspack for sound be good? Screw the downpipe And headers, that basically is a $400 setup with welding from exhaust shop on the glasspack and everything
  10. #150 Re: Mods for my 98 GTP
    Straight pipe sounds like ass. Why not just stick with a 3" downpipe (will also get rid of the ubend) and keep everything else stock. Hell you can just weld on new mufflers if you want a different tone.
    04 Comp G.
  11. #151 Re: Mods for my 98 GTP
    Apr 2012
    Indiana
    Ok, the straight pipe was recommended by someone so I brought it up. But we'll see what happens
  12. #152 Re: Mods for my 98 GTP
    Go to YouTube. Straight pipes on our cars sound like ass. Stock mufflers are fine.
    04 Comp G.
  13. #153 Re: Mods for my 98 GTP
    Apr 2012
    Indiana
    Alright then....I'll talk to my buddy and see if he wants to attempt headers or not
  14. #154 Re: Mods for my 98 GTP
    Jun 2010
    Michigan
    Yes it was, so what can I do to correctly tune this since it is obvious I have no clue what I am doing?
  15. #155 Re: Mods for my 98 GTP
    St Thomas Ontario
    Don't need to weld the headers but you want band clamps. But you also have to take in account sd headers crossover will need adjustment,you will need to bash in the firewall for rear 02.
    But if you just want sound just change the mufflers .. but nothing sounds better the headers. I'll post a link of my exhaust with 2.5" downpipe. Then another vid of with headers if ya want
  16. #156 Re: Mods for my 98 GTP
    I have some local retune the car for you. Meaning sitting in the car with you while your driving recording data and adjusting the tune accordingly. Your in Michigan...that's Grand Prix central surely you can find a tuner.
    04 Comp G.
  17. #157 Re: Mods for my 98 GTP
    Apr 2012
    Indiana
    Links would be perfect man! What do you mean by the crossover will need adjusted? What will that require?
  18. #158 Re: Mods for my 98 GTP
    St Thomas Ontario
    Not much we attached the crossover to the front header then forced it on the rear header, wasnt extremely hard but wasny a direct fit either.
    I'll get vids later. Watching walking dead atm
  19. #159 Re: Mods for my 98 GTP
    Apr 2012
    Indiana
    Sounds good man! I need to get a floor jack before any install. There's an auction tommorow with one and my dad is gonna try and get it
  20. #160 Re: Mods for my 98 GTP
    Jun 2010
    Michigan
    Yes but most are across state, seems most people who deal with this platform live in Grand Rapids or Kalamazoo area.
  1. Trade 98 GTP lite mods for GTP with mods
    By Shifty in forum Wanted To Trade
    Last Post: 10-20-2012, 07:52 PM
  2. gtp mods
    By 03limitedgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-14-2011, 10:59 AM
  3. mods
    By Moriarity81 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-21-2011, 03:14 PM
  4. Next Mods
    By Clar2478 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-03-2009, 02:11 AM
