Thread: Needing dyno run data with XP cam
Results 1 to 6 of 6
  1. #1 Re: Needing dyno run data with XP cam
    Transmission Expert Trannyman95's Avatar
    Fort Wayne, IN
    Our local dyno operater has you fill out a sheet with all the specs and rpm limit you want the engine rev'd to. You could tell him to make a pull to 6500 and if the power is nosing off earlier than that point then you will know by looking at the graph or print out after the pull. I am running the XP cam in my Cutlass and rev to the 6700-6800 mark with it but I also have very agressively ported heads which really help the top end. Most of the stock headed cars that I have put XP cams in seem to pull good to the 6300ish mark and I set the shift points at about 6350-6450 but every car and combo responds differently. In our old 95 prix with an L67 I had a VS cam and ported heads and its peak HP on the dyno was 5800 rpm while most stock cammed cars with rockers peaked about 5300-5400 rpm
  2. #2 Re: Needing dyno run data with XP cam
    TDCRacing
    Guest
    Quote Originally Posted by Trannyman95 View Post
    Yeah the 6300 mark is what i was feeling. So thanks for the input
  1. My Dyno Tune
    By Keifer in forum General Tech Discussion
    Last Post: 07-15-2008, 07:12 AM
  2. Dyno. 541whp.
    By Meemperor in forum Off Topic Discussion
    Last Post: 05-19-2008, 12:33 PM
  3. dyno question
    By nemesis in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-03-2008, 02:11 AM
  4. P1380-Misfire Detected-Rough Road data not available
    By t24moore in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-20-2008, 09:07 AM
  5. Dyno anyone?
    By SD GTP in forum Northeast
    Last Post: 01-12-2008, 02:09 PM
