Thread: A/C Broken in florida heat. PLEASE HELP!
Results 1 to 20 of 39
  1. #1 A/C Broken in florida heat. PLEASE HELP!
    GT Level Member wyrmscar's Avatar
    Jan 2012
    Orlando, Florida
    So recently I recently was in an accident...
    With that in mind this said accident pierced a hole in my condensor as I found out today. Soo the shop i took Otto (my car) to said he needs to replace a few of the parts Along with the AC condesor. Sooo without further adue, if you may please analyze the photo below and Explain What parts exactly are listed in the picture below (aside from condensor of course). This would help me greatly! I plan on pullin junkyard parts cause i aint got money for new shizz.
  2. #2 Re: A/C Broken in florida heat. PLEASE HELP!
    I live here. DirtDog's Avatar
    Jun 2012
    The only actual part on there is the condenser
    And really I would think id just need to take the old condenser out...put new one in...and charge the system. Dunno why their doing all that other stuff
  3. #3 Re: A/C Broken in florida heat. PLEASE HELP!
    Jan 2012
    Orlando, Florida
    Lol... Funny you say that cause i was thinking the same thing. Thank you for your opinion awesome sir! He was trying to tell me about how moisture is getting into the A/C system because of the hole and going to be ruining components inside it.
    I should also mention that when i turn on the A/C the compressor kicks on but no air blows through the vents.
    AND already got a condensor too...
  4. #4 Re: A/C Broken in florida heat. PLEASE HELP!
    Jun 2012
    Ya know....u could probably do it your self. I could under stand them purging the system of all the old stuff cause that'd be good.
    But u should just install the condenser and all ur self. Then have them just vacuum the system out and refill the system
    When I retro-fitted my old truck to 134A from R12 I had to use a special vacuum system to get all the old out of the truck.
  5. #5 Re: A/C Broken in florida heat. PLEASE HELP!
    Join the club my AC is broke as well
    04 Comp G.
  6. #6 Re: A/C Broken in florida heat. PLEASE HELP!
    Jun 2012
    Fix it
  7. #7 Re: A/C Broken in florida heat. PLEASE HELP!
    Nope. It's down the road at the shop let them fix it I ain't got time for that!
    04 Comp G.
  8. #8 Re: A/C Broken in florida heat. PLEASE HELP!
    Jun 2012
    U must have money to waste
  9. #9 Re: A/C Broken in florida heat. PLEASE HELP!
    Not at all. Lack of time to do it myself at this time and I refuse to drive it without AC so it's worth it. It's a rather cheap fix.. So it's worth it.
    04 Comp G.
  10. #10 Re: A/C Broken in florida heat. PLEASE HELP!
    Jun 2012
    Lazy
  11. #11 Re: A/C Broken in florida heat. PLEASE HELP!
    Sike. Took wht little free time I had to put the car back together.
    Let's see..wisdom teeth got pulled a week ago, started skool again and little side jobs = 0 time to mess with AC crap!
    Don't be calling me out bro!
    04 Comp G.
  12. #12 Re: A/C Broken in florida heat. PLEASE HELP!
    Jan 2012
    Orlando, Florida
    Lol you two crack me up! But I agree With red on this one... I got lucky that I got a week long summer break to put the car back together. Otherwise i aint got much time outside of school. Im not immediately worried about AC... I can deal without. I Really hope your right marine in the fact that all i need to do is replace my condensor and fill up freon...
    But im confused becuase what does the condensor have to do with me turnin on the AC and nothing blowing through the vents =/?
  13. #13 Re: A/C Broken in florida heat. PLEASE HELP!
    Jun 2012
    Well nothing blowing through the vents could be a bad blower motor
  14. #14 Re: A/C Broken in florida heat. PLEASE HELP!
    SE Level Member cortneyevans1's Avatar
    Oct 2012
    Fort Walton Beach, Fl
    my a/c blows out warm air like I have the heat on, but weird thing is when I turn it on 1-3 don't blow and turn my lights off but it blows on 4 and 5.
    2004 Grand Prix GTP
    2001 Grand Prix SE
  15. #15 Re: A/C Broken in florida heat. PLEASE HELP!
    Jan 2012
    Orlando, Florida
    Mine doesnt blow anything... But i can hear the compressor kick on :/.
  16. #16 Re: A/C Broken in florida heat. PLEASE HELP!
    Quote Originally Posted by cortneyevans1 View Post
    you probably need a ignition harness.
    Quote Originally Posted by wyrmscar View Post
    your blower fan or resistor took a crap.
  17. #17 Re: A/C Broken in florida heat. PLEASE HELP!
    Jan 2012
    Orlando, Florida
    Weird that my accident would cause that to crap....
    But i believe you as usual.
    So replace Condensor... Fill with freon, And replace blower fan and resistor.
  18. #18 Re: A/C Broken in florida heat. PLEASE HELP!
    if its not blowing at all, hot or cold air, one or the other are bad. fan or the resistor.
    take the glove box off, you should see the fan, check to see if anything has fallen into the squirrel cage and is jamming it. ( maybe something flew into it during the crash) see if you can turn it also, see if is smooth spinning by hand.
    you can also check for power at the resistor and the fan.
  19. #19 Re: A/C Broken in florida heat. PLEASE HELP!
    GT Level Member orange57's Avatar
    Aug 2012
    Chandler, AZ
    They are replacing seals and re lubing the system. When it waspierced you lost some oil with the refrigerant, but can't tell how much. They are doing the correct route so you don't fry your compressor too.
  20. #20 Re: A/C Broken in florida heat. PLEASE HELP!
    Here's what you want to do.. get a seal kit and put your condensor in. Change only the two seals where it connects to the rest of the system. Then have someone vacuum it down and charge it for you.
    Having high and low side gauges along with vacuuming is key to fixing an AC system properly.
    I could make a case for a new drier (also pag oil for the drier) and then potentially an orifice tube (you'd hate me if I suggested that though). Likely you can just do what I said at first and have good ac.
  1. No heat on drivers side, but heat on passenger side.
    By maceman in forum General Tech Discussion
    Last Post: 04-05-2013, 06:57 PM
  2. Old Thread
    By SpeedGrid in forum General Tech Discussion
    Last Post: 09-03-2012, 09:23 PM
  3. S. Florida GTP
    By wpbboy81 in forum Introductions/Noob Questions
    Last Post: 09-08-2011, 07:39 PM
  4. New from Florida
    By taximech in forum Introductions/Noob Questions
    Last Post: 05-19-2009, 06:12 PM
  5. SW Florida?
    By Vespers47 in forum Southeast
    Last Post: 04-12-2009, 01:44 PM
