Thread: SRS Panel Coming Off?
Results 1 to 4 of 4
  1. #1 SRS Panel Coming Off?
    GTX Level Member EJOUIE's Avatar
    Newnan, GA
    The airbag panel and the dash is coming off right at the corner where it says SRS. It appears that some sort of clip has failed. Normally this would be an easy fix with removing the panel, replacing the clips and then putting it back, but the airbag makes things tricky. How do I go about fixing this safely?
    97 GT white 4 door-SOLD
    Cherry 2005 Impala LS- Front and Rear GMPP Strut Tower Braces
  2. #2 Re: SRS Panel Coming Off?
    GT Level Member Jakescoots's Avatar
    Spring Lake, Mi
    Unplug the airbags? Disconnect battery for a while so it holds no charge?
    Does removing the spare count as weight reduction?
    Badges on a car are just advertisements....Everyone already knows what it is. And if they dont, its a mystery. People like mysteries.
  3. #3 Re: SRS Panel Coming Off?
    Dec 2012
    Where 4T65E's were born
    Anytime you're working with or near airbags, make sure the battery is disconnected. You may even want to leave it disconnected for an hour before. So basically what he said the second time. ^
    Then you won't have any issues with airbags going off, it's perfectly safe.
    Sold.
  4. #4 Re: SRS Panel Coming Off?
    Newnan, GA
    anybody happen to have the part number for the clips?
  1. Instrument Panel Out!!!!!
    By Torell10 in forum Audio, Security & Visual Electronics
    Last Post: 03-17-2012, 01:53 PM
  2. Door Panel fix
    By sattler in forum General Tech Discussion
    Last Post: 05-07-2011, 01:45 PM
