Thread: CASE Learn Scanner's
Results 1 to 9 of 9
  1. #1 CASE Learn Scanner's
    GT Level Member K Kraziee's Avatar
    Apr 2013
    Milwaukee
    I know this has been brought up a billion times, but I could't find a good list of scanner's that will perform the CASE relearn. I know the GM Tech II can do it and HPtuner and such. Will the Scangauge II be able to perform this? Or should I just take it to the dealership and spend $100 to get it done? Also will mom and pop shops have the ability to do this if it's a good place? Thanks
    DD: 2000 Pontiac Grand Prix GTP
    3.5 ZZP MPS, HAI, ZZP Ported Throttle Body, PLOG, 3" Catless DP, Water pump and Alt. UD Pulley, Custom Tune
  2. #2 Re: CASE Learn Scanner's
    Apr 2013
    Milwaukee
    Is this able to do a CASE learn? EECR1, Code Reader, CarScanĀ®
  3. #3 Re: CASE Learn Scanner's
    That wont do it.
    A tech 2 scanner, Modis, Aeroforce, HP tuners are pretty much your only options.
  4. #4 Re: CASE Learn Scanner's
    GTP Level Member Twizted 1's Avatar
    Jul 2013
    Summertown Tn
    I wouldn't think a code scanner would be able to do it.
    Yes your local shop should be able to do a case learn.
    Or you could get on fleabay and buy a snapon brick on thecheap.
  5. #5 Re: CASE Learn Scanner's
    Jul 2013
    Summertown Tn
    The scanner I'm talking about is a Snapon MT2500. They are CHEAP since all of the new scanners hit the market.
  6. #6 Re: CASE Learn Scanner's
    Apr 2013
    Milwaukee
    I'm pretty sure the MT2500 is pre 1996.
  7. #7 Re: CASE Learn Scanner's
    Jul 2013
    Summertown Tn
    Nope I can scan 1987- 2001 with mine, and could go newer if I bought the chips for it. But I bought the verus instead. I keep the brick in my trunk just in case I need it while away from home.
  8. #8 Re: CASE Learn Scanner's
    Apr 2013
    Milwaukee
    So this one would work for a relearn? Snap on MT2500 Diagnostic Scan Tool Kit | eBay
  9. #9 Re: CASE Learn Scanner's
    Jul 2013
    Summertown Tn
    I wouldn't give $10 bucks for that in the condition its in unless I needed parts for mine.
    You will pay a couple hundred or more for a good one. But it will scan any vehicle from 87-08 if you have the correct modules and personalization keys.
    If you decide to buy one be sure it will scan GM through the year model you own and that it has the K9 personalization key.
  1. Need help with CASE learn
    By fremmy182 in forum PCM Tuning
    Last Post: 06-13-2012, 08:42 PM
  2. Case Learn...
    By Z34Phoenix in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-07-2012, 04:53 PM
  3. CASE Learn help
    By Agentlongwood in forum PCM Tuning
    Last Post: 03-22-2011, 09:33 AM
  4. case learn?
    By bbptech in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-06-2010, 06:07 AM
