Thread: Rear Driver Window Regulator Issue
Results 1 to 9 of 9
  1. #1 Rear Driver Window Regulator Issue
    May 2012
    Bloomington, IN
    So my regulator went out. Not sure if I can get away with just replacing the motor or do I need to replace the whole assembly. What can I get away with, anyone know, thanks
  2. #2 Re: Rear Driver Window Regulator Issue
    Replace the whole thing
  3. #3 Re: Rear Driver Window Regulator Issue
    May 2012
    Bloomington, IN
    I have a 2004 Grand Prix N/A, just not worth the headache to just do the motor or does the whole assembly fail?
  4. #4 Re: Rear Driver Window Regulator Issue
    the cables wear on the sliders, then break, and the motors quit, its easy enough to just change the whole regulator.
  5. #5 Re: Rear Driver Window Regulator Issue
    GT Level Member 2FASTGTP's Avatar
    Apr 2012
    Indiana
    Had mine replaced a while back. You're looking at about a $200 plus fix.
  6. #6 Re: Rear Driver Window Regulator Issue
    If you do it yourself it's only about a $30 fix
  7. #7 Re: Rear Driver Window Regulator Issue
    Florida
    Gotta replace my passenger side one,apprently its an $80 part for whole assembly. But im tackling.it myself.
  8. #8 Re: Rear Driver Window Regulator Issue
    depends on where you buy the regulator, one from a dealer would cost more. but should last longer, vs a cheap ebay one.
  9. #9 Re: Rear Driver Window Regulator Issue
    GT Level Member orange57's Avatar
    Aug 2012
    Chandler, AZ
    My rear passenger side doesn't work at all. I need to do a little more troubleshooting to determine if it is the motor or power getting to it.
  1. WTB Rear Driver Window regulator motor etc
    By TeacherCreature in forum Wanted To Buy - Parts
    Last Post: 05-18-2013, 12:57 PM
  2. Do 04+ have the window regulator issue
    By Fahrenheit in forum Visual/Body Modifications
    Last Post: 04-03-2013, 05:36 AM
  3. Rear Driver window regulator
    By rudedude in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-28-2009, 11:23 AM
