Thread: a few questions
Results 1 to 16 of 16
  1. #1 a few questions
    Apr 2012
    rhode island
    Ok im tryin to finish up my car and running into a few problems...
    im tryin to wire my boost gauge and oil pressure gauge and i cant find a good ignition wire to tap into, im hopin not to have to put a power switch in. i read to tap into the dimmer wires, but i only found a constant and not an ignition switch. any ideas???
    also... what is the best way to get the oil pressure sensor out??? and can I some how tap into the stock boost gauge so i dont have to run another vacuum line, and will it show the higher boost levels??
    lowered my car, added spacers and new solid mounts and the engine seems to be out place now, for example the mounts no longer line up. do i need all the spacers or is that not the reason for the misalignment?
    thats it for now, thanks in advance, sorry if this is not in the right spot
  2. #2 Re: a few questions
    Houston
    What year? No you cannot tap into the stock boost gauge. It is electric, the boost gauge you have is mechanical. The boost levels it will show is the boost level it has, no more no less.
  3. #3 Re: a few questions
    Apr 2012
    rhode island
    04 comp g
  4. #4 Re: a few questions
    Houston
    Add a circuit to your sunroof fuse and run the line over to the gauge.
  5. #5 Re: a few questions
    Apr 2012
    rhode island
    circuit? not 100% on what u mean by that
  6. #6 Re: a few questions
    Can't help, sorry. We don't know if you drive a 97, an 04 or a yugo.
    Please provide more info.
  7. #7 Re: a few questions
    Quote Originally Posted by illy View Post
    04 comp g
    bill, you really should have some rest on that cold of yours.
  8. #8 Re: a few questions
    Houston
    This is an add a circuit. Your sunroof fuse is switched. Add this in its place and connect the wire to your gauge.
    http://www.autozone.com/autozone/acc...questid=910103
  9. #9 Re: a few questions
    Apr 2012
    rhode island
    cool thanks. any ideas on the other problems lol
  10. #10 Re: a few questions
    Houston
    To remove the oil pressure sensor, drain oil and use a wrench to remove stock sensor. Install sensor that came with the gauge. (depending on what gauge you got, you'll probably need a thread adaptor). As for the lowering, Bio or Drunkie could probably answer that. Im thinking you may need shorter dog bones.
  11. #11 Re: a few questions
    Dave..I swear it wasnt' there when I read it.
  12. #12 Re: a few questions
  13. #13 Re: a few questions
    Whatever.. you all look the same to me.
  14. #14 Re: a few questions
    Houston
    Hahaha
  15. #15 Re: a few questions
    Banned
    Jan 2013
    Colorado
    Is there a spot in the engine to tap into a vacuum line to hook up an aftermarket mechanical vacuum/boost gauge?
  16. #16 Re: a few questions
    SE Level Member Jcinstalls's Avatar
    Feb 2013
    Missoula, MT
    The best place to get power from is the ignition harness under the steering wheel. Use a meter and probe the big gauge ignition, acc, batt, and second ign/acc wires there they can handle the load and its probably close to your gauges. Never use t-taps on anything ever especially these wires. Also I've always been a fan of oil filter sandwich adapters for oil temp and pressure gauges. It gives you lots of room to work with and is easier imo. 30$ on eBay. On my 3100 i taped the upper intake for my boost gauge, it should be a dedicated line to be accurate right?
  1. Replies: 2
    Last Post: 01-30-2012, 09:40 AM
  2. A few questions about a GXP
    By Walleyealx in forum General Tech Discussion
    Last Post: 10-08-2011, 09:34 PM
  3. New guy w/ questions
    By Koovy in forum Introductions/Noob Questions
    Last Post: 06-19-2010, 08:30 PM
  4. Alky Questions & Other Related Questions.
    By rynoman03 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-22-2010, 07:57 AM
  5. Car questions
    By Panther427 in forum 5.3L V8 (LS4)
    Last Post: 07-18-2009, 12:01 AM
