Thread: F body brake upgrade question
Results 1 to 20 of 29
  1. #1 F body brake upgrade question
    GTP Level Member Austins01GP's Avatar
    Nov 2010
    Maryville, MO
    Well I'm in the middle of doing an f body brake upgrade and I'm not sure where these brackets go,
    any info!?
    thanks
    // 1992 Nissan 300zx Twin Turbo (More RWHP than the Comp G)
    // 2005 Comp G
    CLICK ME!! for my Z Build and Comp G
  2. #2 Re: F body brake upgrade question
    Nov 2010
    Maryville, MO
    S*%+. I just realized I shoulda posted in the brake section, if some one wound or wants to move this feel free
    // 2005 Comp G
  3. #3 Re: F body brake upgrade question
    Those hold the brake pads on the bracket.
  4. #4 Re: F body brake upgrade question
    Nov 2010
    Maryville, MO
    Like this?
    // 2005 Comp G
  5. #5 Re: F body brake upgrade question
    That seems right but i'm not sure.
  6. #6 Re: F body brake upgrade question
    GTX Level Member 97gtpjoe's Avatar
    Jan 2009
    Chandler, Arizona, United States
    Mine didnt have those, I had clips but on the caliper itself maybe since they where 98+ setup from a TA
    Speed Daddy Headers, Open Cone, 3.4 MPS , AL605s , 180* Stat
  7. #7 Re: F body brake upgrade question
    Nov 2010
    Maryville, MO
    It seems right, the pads hold in place and nothing is rubbing on
    And I gotcha
    // 2005 Comp G
  8. #8 Re: F body brake upgrade question
    Nov 2010
    Maryville, MO
    Well I've got the brakes on and everything and bled them correctly like 5 times, but after building up pressure, the car looses brake pressure any ideas?
    // 2005 Comp G
  9. #9 Re: F body brake upgrade question
    GT Level Member cmal37's Avatar
    May 2011
    Tampa FL near USF
    are the caliper on the right way? bleeders pointing up?
    GMPP Struts, F body brakes, CAI, Ubend, resonator, and cat delete, 180tstat, SD headers, 3.4 Pulley, OverKill PCM,http://www.grandprixforums.net/my-bl...res-60017.html
  10. #10 Re: F body brake upgrade question
    Nov 2010
    Maryville, MO
    Yeah they are on the right way, I'm thinking I still have air in the system, either that or the proportioning valve.
    // 2005 Comp G
  11. #11 Re: F body brake upgrade question
    Take a pic of the installed calipers. You bleed the rear pass, rear drivers, front pass, then front drivers side?
  12. #12 Re: F body brake upgrade question
    Nov 2010
    Maryville, MO
    yeah i bled them in that order, ive actually put a lot of fluid through the system
    and ill get a pic up later on in the day im at work right now
    // 2005 Comp G
  13. #13 Re: F body brake upgrade question
    did you let the master cylinder go dry while bleeding the brakes? if it got real low you may have sicked air into the lines by the abs pump. look for a bleeder on the abs or off the master, some have it some dont, depends on the year of the car.
  14. #14 Re: F body brake upgrade question
    Nov 2010
    Maryville, MO
    yeah i let the master cylinder run dry...
    i was looking for a bleeder but couldnt see one yesterday
    would a 2001 car have that bleeder?
    // 2005 Comp G
  15. #15 Re: F body brake upgrade question
    i know the 97 and 98 had it, the newer ones dont seem to have it.
    you can have some one pump the brakes, then they hold them, just like bleeding the caliper, then crack the line bolt loose off the master, if its got air, this will bleed it out, wrap a rag around the line, as it will fly out fast if you crack it to much.
  16. #16 Re: F body brake upgrade question
    Nov 2010
    Maryville, MO
    sweet, thanks for the info, ill give that a try and let you guys know soon
    // 2005 Comp G
  17. #17 Re: F body brake upgrade question
    Nov 2010
    Maryville, MO
    here is the other one the passenger side
    // 2005 Comp G
  18. #18 Re: F body brake upgrade question
    Nov 2010
    Maryville, MO
    I have pressure when the car is off, but when it's running the brakes have to be pushed in to floor before they engage properly, (i haven't bled the abs/BMC yet no one to help) if I pump them while the car is running they start to build pressure but them they loose it.
    and I Know!! There is like zero clearance lol
    // 2005 Comp G
  19. #19 Re: F body brake upgrade question
    Nov 2010
    Maryville, MO
    Here is a pic of one caliper installed
    // 2005 Comp G
  20. #20 Re: F body brake upgrade question
    looks good, did you get the pedal back yet?
    if your running stock wheels, be careful putting the wheels back on, thats how them chips you have on the caliper happen, you got like a 1/2 inch of space now.
  1. F-Body front brake upgrade
    By jlgp2007nc in forum General Grand Prix Discussion
    Last Post: 03-26-2013, 09:26 PM
  2. f body brake upgrade fail......defeated and need help
    By asite57 in forum Brakes/Suspension/Chassis
    Last Post: 07-07-2012, 01:07 PM
  3. F-body brake upgrade
    By wpbboy81 in forum Brakes/Suspension/Chassis
    Last Post: 11-04-2011, 12:52 PM
  4. F-Body Brake Upgrade
    By Phyrstorm in forum Brakes/Suspension/Chassis
    Last Post: 07-19-2010, 05:53 AM
