Thread: f body brake upgrade fail......defeated and need help
Page 1 of 3 123 LastLast
Results 1 to 20 of 44
  1. #1 f body brake upgrade fail......defeated and need help
    GTX Level Member asite57's Avatar
    Oct 2011
    Michigan
    i recently installed Wbody stores 12" brake upgrade kit on my 99 gtp and when i got it all done and bled out i start it up and the pedal goes right to the floor no brakes at all, i re-bleed the brakes using several different methods and finally i used a vacuum bleeder still right to the floor im at a complete loss i dont know what to do if i bleed it again theres no air just a steady stream i dont know what to do...any help what be greatly appreciated
    SOLD. 99 GTP - Open Cone, ZZP STB ,GMPP Front & Rear Sway Bar, 3" DP & Cat-Back, Built Trans, 12'' Brakes, Tune
    http://www.grandprixforums.net/gtp-t...ack-67489.html
    04 SRT4 - Bone Stock....For Now
  2. #2 Re: f body brake upgrade fail......defeated and need help
    Mar 2012
    NC
    Are the bleeders at the top of the caliper?
  3. #3 Re: f body brake upgrade fail......defeated and need help
    Oct 2011
    Michigan
    no the bleeders are at the bottom of the caliper
  4. #4 Re: f body brake upgrade fail......defeated and need help
    Mar 2012
    NC
    Flip sides so bleeders are at top and re-bleed.
    Ohio
    Fail
  6. #6 Re: f body brake upgrade fail......defeated and need help
    Mar 2012
    NC
    I've seen this one a few too many times. LOL
  7. #7 Re: f body brake upgrade fail......defeated and need help
    Oct 2011
    Michigan
    so what your tellin me is i put the calipers on the wrong sides and all i need to do is swap them and rebleed then it will be all good?
  8. #8 Re: f body brake upgrade fail......defeated and need help
    Mar 2012
    NC
    Exactly.
    Ohio
    Yessir, any type of bleeder screw is alway supposed to go up
  10. #10 Re: f body brake upgrade fail......defeated and need help
    Oct 2011
    Michigan
    wow i feel like a moron guess i just got to excited to get the job done thank you guys you just saved me a ton of money i was left with towing it to a shop i was plum out of ideas
  11. #11 Re: f body brake upgrade fail......defeated and need help
    Feb 2010
    TN
    Quote Originally Posted by asite57 View Post
    If you learned from it and it keeps you from making the same mistake again you are simply being schooled. If you make the same mistake again and again, then you are a moron.
  12. #12 Re: f body brake upgrade fail......defeated and need help
    GT Level Member Vegas~Blown's Avatar
    Aug 2008
    vegas
    Quote Originally Posted by Logan541 View Post
    word.
    Ohio
    Lol its cool
  14. #14 Re: f body brake upgrade fail......defeated and need help
    Oct 2011
    Michigan
    i just can not believe its that simple
  15. #15 Re: f body brake upgrade fail......defeated and need help
    Mar 2012
    NC
    It is....believe us.
  16. #16 Re: f body brake upgrade fail......defeated and need help
    Portland Oregon
    Bleeders are at the top because air bubbles go up
    Ohio
    Just like the bleeder screw for our coolant.
  18. #18 Re: f body brake upgrade fail......defeated and need help
    this is not a gp lol
    but see the bleeder up top on the left side of the caliper, yeah simple boo boo. but once you get them flipped you'll love your new brakes.
  19. #19 Re: f body brake upgrade fail......defeated and need help
    Oct 2011
    Michigan
    well i guess its a learning process
  20. #20 Re: f body brake upgrade fail......defeated and need help
    That Loud Guy 1LoudGrandPrix's Avatar
    Cedar Rapids, IA
    We all make mistakes it's part of being human.
    98 Camaro SS 46k LS1, T56, All Stock. 00 GMC Sierra 2wd ECSB 106k Lm7, 3.73s tow needs lowered..
    01 Grand Prix GTP "201k" ~111k on motor, ~46k on trans, headers, 3.4 and a tune to come.
    01 Grand Prix GT 168k: Mods: Tune by TheOtherNick. Stereo: 320A alt,4 runs 0/1, XS D3400 front, 1 JYP 80ah Lithium rear, 2 Twisted Sounds 3500s, 2 Sundown Audio NightShade v.3 7 National Records..
  1. F-body brake upgrade
    By wpbboy81 in forum Brakes/Suspension/Chassis
    Last Post: 11-04-2011, 12:52 PM
  2. body kit+altezza tails+spray paint job=rice fail
    By jakewet28 in forum Off Topic Discussion
    Last Post: 02-18-2011, 04:26 PM
  3. brake parts to get for brake upgrade??
    By colindunn in forum Brakes/Suspension/Chassis
    Last Post: 01-03-2011, 08:59 PM
  4. F-Body Brake Upgrade
    By Phyrstorm in forum Brakes/Suspension/Chassis
    Last Post: 07-19-2010, 05:53 AM
