If I were you, to prevent all that work, I would have just set up an antilag switch on the rear motor to pull timing way down to spool the turbo.
I already switched the turbos around. But going to the track only Friday, it's raining today.
But yes an antilag timing map in the low RPM full throttle range would help.
So far it seems the swap is just right. The 6262 spools about the same up front then the small GTX3076R in the back. So I can brake boost both at the same time which makes it easier to launch.
