You went 10.9 in a RWD rear engine Fiero, just the car plus the parts to build the project, you broke the budget for the parts car...
What is wrong is most of things you've said about my project before I ran the times I did. Now your angry because you've been proven wrong.
No one that I can see as ever taken as much stock parts to that limit before. I wanted to prove it could be done, because I hate the negative attitudes many throw at others because of their own failure. It doesn't mean you failed at somethings others will.
You went a different route yourself.
And yes the parts car was a super cheap build other than the time to build it. The turbo cost me nothing, it was sitting at the shop for a year because it wasn't right for most other projects we worked on. Now that turbo is going in the twin engine set up, so it was no money lost. Almost everything I put in the parts car was reusable for a better more extreme project.
Everything was calculated and it worked out perfectly.
So buzz off with your negative attitude.
