Thread: A/C Blower fine but airflow weakens after long distance?
Results 1 to 10 of 10
  1. #1 Re: A/C Blower fine but airflow weakens after long distance?
    GTP Level Member LeadfootCJ7's Avatar
    Oct 2012
    Houston, TX
    It sounds like is evap core is freezing up. I have seen it a few times before including on my wife's Camaro. When you park it for a little bit do you notice quite a bit of water coming out of the drain in the firewall and hitting the ground under the engine? Usually this is a sign of the ice melting. Most of the time it means the A/C has a leak / low on freon and this is causing the freezing up. It could be a bad compressor or switch causing the compressor the over pressure the system as well.
    2007 Grand Prix GXP;2002 Camaro Z28 - tune, CAI, and exhaust
    2006 GMC 2500HD - ATS high flow manifolds and uppipes, turbo back exhaust, blocked EGR, Denali headlights, Reflexxion Cown Hood
    1994 Olds Cutlass Supreme 2 door
  2. #2 Re: A/C Blower fine but airflow weakens after long distance?
    Donating Users
    Jan 2013
    Huntsville, AL
    Interesting! I never thought of that.
    Yes! There is an unusual amount of water that drains out after I stop. I went out to Advance Auto, purchased the correct R-134a and a gauge, and checked the pressure: it was about 30% below optimal. I filled it to the middle of the recommended range, so I guess we'll see what happens.
    The A/C button audibly engages/disengages the compressor clutch, and it automatically disengages after a while, so the compressor seems ok. I'll keep that in mind as a possibility though.
    I'm leaving the country tomorrow for 3 weeks, but after I return I'll make sure to go on a long drive and see if adding refrigerant solved the issue and post back. Thank you so much for your help!
    Komrad36
    1998 Grand Prix GTP. Open cone intake, ZZP downpipe, dogbone flip.
  1. GM 85mm LS6 LQ4 MAF Mass Airflow kit
    By Spartan GL in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-24-2017, 06:08 PM
  2. Heater airflow significantly weakens when temp is set to ‘hot’
    By Diron in forum General Tech Discussion
    Last Post: 01-25-2012, 01:11 PM
  3. Mass Airflow Sensor question
    By Dean10e in forum General Tech Discussion
    Last Post: 11-11-2011, 07:31 PM
  4. remote key fob distance
    By 03impala9c1 in forum General Tech Discussion
    Last Post: 11-16-2009, 07:41 PM
  5. Good reasonably priced tranny place withing driving distance of Houston TX?
    By Tengis in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-14-2008, 09:52 AM
