Thread: how do you scan for KR using torque pro ?
Results 1 to 20 of 21
  1. #1 how do you scan for KR using torque pro ?
    GTX Level Member Doug 97 gtp's Avatar
    Sep 2011
    palm harbor florida
    either my car has 0.0 KR and no knocks counted or im doing something wrong lol
    1997 GTP . repainted in jet black with blue pearl. rebuilt motor
    with vs cam ported heads and blower.
  2. #2 Re: how do you scan for KR using torque pro ?
    May 2008
    Winnipeg, MB
    if its reading other sensors just fine then maybe you don't have any KR
    2007 Pontiac Grand Prix
  3. #3 Re: how do you scan for KR using torque pro ?
    Sep 2011
    palm harbor florida
    yeah all the other sensors seem to be normal and everything updates within 1 second. but i havent seen the KR sensor move once
  4. #4 Re: how do you scan for KR using torque pro ?
    GT Level Member atj8's Avatar
    Midwest
    have u gone into settings and added PIDs/sensors?
  5. #5 Re: how do you scan for KR using torque pro ?
    GT Level Member comatoast's Avatar
    Nov 2012
    MN
    When I run the separate add on that tells you how many times it knocked I get zero. When I'm actually looking at the kr gauge in torque it seems every time I'm going up a hill, passing etc I will see 2-4* kr. Don't know how that's possible as my car is bone stock other than 605s, 180 stat and a come filter on the end of the maf. And I'm running 93..
  6. #6 Re: how do you scan for KR using torque pro ?
    GTX Level Member dbextreme's Avatar
    Nov 2009
    Tennessee
    From what I understand stock cars knock..... Dunno why, but they do.
    I have a fresh rebuild, mods in my sig, with an Intense custom "canned" tune and I scan with an Aeroforce. I have 0KR. I drive my car normal daily, I do plenty of WOT pulls, and the car has seen the strip multiple times. I, like you, thought it was not working. One day coming up the mountain before I got my 5v reference figured out, the car hiccuped triggering the SES light. When the light triggered I saw a blip of KR for a split second (due to computer kicking into limp mode under load) then nothing so i know it works. You proably don't have any KR.
    1999 GPGT - L26, Ported Top Swap, XP Cam, 3.2 MPS, 42.5#, N*, LQ4, SD Headers, Double Roller, TEP Race Trans w/Stand alone Cooler, Precision Industries 3000RPM Stall, 75 Shot Nitrous Express Proton Kit w/Purge, 3" Dual Borla Pro XS, Corsa Dual 3.5 Tips, 5% Tint
    1995 Firebird Formula - Under the Knife
  7. #7 Re: how do you scan for KR using torque pro ?
    Sep 2011
    Copperas Cove, TEXAS
    I get flash KR before the shift during WOT and all I have is a Overkill PCM. Have someone tap the oil pan with a hammer while you monitor the Torque App. If you still don't have KR readings, then check the wires to the Knock sensor. I had to fix the wiring on my rear knock sensor.
  8. #8 Re: how do you scan for KR using torque pro ?
    Sep 2011
    palm harbor florida
    well when i was putting in my motor after it was rebuilt i forgot to plug in the sensor but i finally got it after about 20 minutes and i know the front one is on. what will knocking on the oil pan do ?
  9. #9 Re: how do you scan for KR using torque pro ?
    Sep 2011
    palm harbor florida
    Quote Originally Posted by dbextreme View Post
    i want to say i dont but thats hard to belive. vs cam flipped mountts 90# springs with 605's and stock exhaust... cant be right unless i found the perfect setup for no kr lol
  10. #10 Re: how do you scan for KR using torque pro ?
    Nov 2012
    MN
    Quote Originally Posted by Doug 97 gtp View Post
    Show false knock I'm assuming?
  11. #11 Re: how do you scan for KR using torque pro ?
    Nov 2012
    MN
    Thanks for the heads up guys. I'll look into it a little more once my overkill PCM is in.
    Also is there any difference between running a cone filter off the maf on the 04+ vs paying $200-300 for an intake that to me seems like the same thing?
    Sorry op. I'm done being a douche and jacking your thread
  12. #12 Re: how do you scan for KR using torque pro ?
    By smacking the motor, you make a noise/tone that the KR sensor will pick up as knock and retard the timing, so when its hit with something and senses that it will show on the gauge if the sensor is reading or not.
    And 1 second is a long time compared to how quicky a aeroforce or a tuning program gets data.
    So its hard to say if you have kr or don't have kr.
  13. #13 Re: how do you scan for KR using torque pro ?
    Sep 2011
    palm harbor florida
    i was just guesstimating it update too fast to actually know how long it takes
  14. #14 Re: how do you scan for KR using torque pro ?
    Nov 2009
    Tennessee
    I'm betting it's all in the cam!!! If you had a stock cam you'd probably be knocking. You've added almost .1 more lift, breathing a lot better. Hell I wish our motors came from the factory with larger cams, but GM didn't want them pumping out more HP then the Z28's and Corvettes..
  15. #15 Re: how do you scan for KR using torque pro ?
    Sep 2011
    palm harbor florida
    yeah they should have though. would of been bad ass
  16. #16 Re: how do you scan for KR using torque pro ?
    GT Level Member penright's Avatar
    Mar 2013
    United States
    I have a torque pro, did you customize it with a PID to get to the KR reading?
    I was looking at mine last night and did not see it, of course being a guy, it may have been in plain sight and I just missed it.
    07 Grand Prix GXP (My Daily Driver and future toy) (120,000+)
    97 Grand Prix GT (Project Car) (178,000+)
    02 Mustang Convertible (Wife's Toy) (75,000+)
    17 Honda Civic (Wife's Daily Driver)
  17. #17 Re: how do you scan for KR using torque pro ?
    Sep 2011
    palm harbor florida
    yeah i did i have the KR sensor and the KR counter and both of them mover 1 bit. also i replaced both of my knock sensors on the block
  18. #18 Re: how do you scan for KR using torque pro ?
    Sep 2011
    palm harbor florida
    ok so i just tested my kr gauge by hitting the oil pan with a mallet and the gauge didn't move one but stayed at 0.0 and then over the past couple of days i keep getting random readings like 0.2 ,0.5 and 0.7, does anyone know what could be wrong ? like i said i replaced both knock sensors and they are both plugged in. could i possibly tap the sensor itself to see if it will change ?
  19. #19 Re: how do you scan for KR using torque pro ?
    Feb 2009
    flintnasty MI
    your car is fine.. 0kr all the time is not hard to achieve even on accident.
    As far as hitting the motor with a hammer goes... it will not work unless you are driving down the road and you can hit it at the perfect time, alot of times in a row.
  20. #20 Re: how do you scan for KR using torque pro ?
    The Boss Iceman6669's Avatar
    Jun 2011
    I have to agree with the second part of this.. I was NOT able to get my car to knock just by hitting the motor/oil pan/headers/crossover with ANYTHING.. Even tried doing it with the Car in Drive.. Nothing...
    2011 F-150 Yote powered
  1. Replies: 7
    Last Post: 04-19-2012, 12:44 AM
  2. my scan
    By 99prixgt in forum PCM Tuning
    Last Post: 09-05-2010, 03:11 PM
  3. pcm scan
    By chrisLB in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-28-2010, 10:32 PM
  4. take a look at this scan!
    By RICE KILLER in forum PCM Tuning
    Last Post: 07-15-2010, 08:23 PM
  5. Replies: 12
    Last Post: 02-08-2009, 01:06 AM
