Thread: 2002 cooling fans
Results 1 to 15 of 15
  1. #1 2002 cooling fans
    Jun 2013
    illinois
    2002 cooling fans wont run, unplugged temp sensor and they run, temp guage quits working when unplugged as expected. changed temp sensor and it didnt fix it. Any ideas??
  2. #2 Re: 2002 cooling fans
    Check the fuse and relay?
  3. #3 Re: 2002 cooling fans
    Jun 2013
    illinois
    Dont think fans would run with sensor unplugged if fuses or relays were bad
  4. #4 2002 cooling fans
    Jun 2013
    illinois
    2002 cooling fans wont run, unplug temp sensor and they come on, changed temp sensor and they still wont run. any ideas???
  5. #5 Re: 2002 cooling fans
    Is the car even getting hot enough for them to come on?
    Temps need to reach 214 and 228 for them to run.
    Also do the fans turn on with the AC on?
  6. #6 Re: 2002 cooling fans
    GT Level Member Erik Adam Rodriguez's Avatar
    Sep 2012
    bridgeport,NY
    stock tune? my fans kick on at 200
    02 grand prix gt- L67 swap, ZZP 1.0 pcm, thrasher CAI, SLP 2.5 catback, A/C delete, 02 emulator, poly dog bone mounts, 6000k projectors with CCFL halos, 12 in slotted front rotors, ported blower and intake, evap and EGR deleted, 12" kicker cvr with 1000 watt amp, alpine cda 9886 deck
  7. #7 Re: 2002 cooling fans
    Quote Originally Posted by Erik Adam Rodriguez View Post
    If the car in untouched modding wise from the factory, the settings are roughly 214 fan 1 and 228 fan 2. View any file from 97-03 and it should be that.
  8. #8 Re: 2002 cooling fans
    Jun 2013
    illinois
    No fans dont come on with AC
  9. #9 Re: 2002 cooling fans
    Sep 2012
    bridgeport,NY
    ??????????? you speaking english? notice i was asking a question not making a statement
  10. #10 Re: 2002 cooling fans
    Jun 2013
    illinois
    We run the temp up to 240 on the guage, dont know if its accurate. we assume it has a stock tune
  11. #11 Re: 2002 cooling fans
    Sep 2012
    bridgeport,NY
    try the fuses and relays as stated before, then move to the temp sensor itself they cheap so i would throw one at it
  12. #12 Re: 2002 cooling fans
    Jun 2013
    illinois
    Fans wouldnt run with unplugged temp sensor if it was bad fuses or relays, have changed sensor, no change
  13. #13 Re: 2002 cooling fans
    Sep 2012
    bridgeport,NY
    you have a short somewhere then
  14. #14 Re: 2002 cooling fans
    Jun 2013
    illinois
    Will try and trace it out and see whats going on, thanks
  15. #15 Re: 2002 cooling fans
    Trying fuses and relays is free to do so instead of saying its not that without trying it just try it.
  1. cooling fans
    By polarisdescent in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-07-2012, 04:28 PM
  2. cooling fans on 90 G.P.
    By TIMS TURBO in forum General Tech Discussion
    Last Post: 05-01-2012, 06:34 AM
  3. cooling fans always run
    By jaxso6 in forum 3.1L V6 (LHO/LG8)
    Last Post: 11-25-2011, 08:33 PM
  4. Cooling Fans Not Working
    By 1FASTGTO in forum 3.1L V6 (LHO/LG8)
    Last Post: 07-23-2011, 01:17 PM
  5. Cooling fans always on?
    By oldschoolpontiacs in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-14-2009, 01:29 AM
