Thread: Service Engine Soon: Grand Prix GT 3800: P0102 & P1133
Results 1 to 13 of 13
  1. #1 Service Engine Soon: Grand Prix GT 3800: P0102 & P1133
    May 2013
    Mississippi
    My service engine soon light came on this morning so I went to Auto Zone for a free scan. The following codes came up on the computer and I have a more detailed print out that the guy gave me.
    P0102:
    (Man. absolute pressure)/BARO or MAF(Mass Air Flow) / VAF(Vane Air Flow) sensor condition.
    Possible Causes:
    1. Vaccuum hose off, cracked, or passage blocked.
    2. Throttle body intake tube loose, off or cracked
    3. Barometer/MAP defective
    4. Vane Air Flow/Mass Air Flow sensor dirty or defective
    P1133:
    Heated Oxygen sensor - Bank 1 Sensor 1 (H02S11), insufficient switching
    Possible Causes:
    1. Failed H02S11 (Bank 1, Sensor 1) heater circuit.
    2. H02S11 (Bank 1 Sensor 1) signal shorted the ECM ground
    3. Improper oxygen supply to sensor - Check sensor connector and wires
    The guy recommended to put some fuel cleaner but I don;t know if thats just a sales pitch. Would you guys have any recommendations??? How safe would it be to drive it for now? thanks again!
  2. #2 Re: Service Engine Soon: Grand Prix GT 3800: P0102 & P1133
    check the wires from the plug to the maf for damage, if they look ok its time for a new maf, junk yard mafs are cheap and work better then after market maf's. theres also a fuse for the maf, check that as well.
    and it looks like you need a new o2 sensor. again check the wires that lead to it, as they can get burnt or damaged as well. that would be the one in the rear manifold back side of the engine.
  3. #3 Re: Service Engine Soon: Grand Prix GT 3800: P0102 & P1133
    Step one..check the vacuum to the map sensor.
  4. #4 Re: Service Engine Soon: Grand Prix GT 3800: P0102 & P1133
    May 2013
    Mississippi
    if it goes unattended what are the possible consequences???
  5. #5 Re: Service Engine Soon: Grand Prix GT 3800: P0102 & P1133
    bad gas mileage. and a clogged cat if your o2 is making the engine over fuel.
  6. #6 Re: Service Engine Soon: Grand Prix GT 3800: P0102 & P1133
    May 2013
    Mississippi
    I have noticed the engine sound "louder" or perhaps the sound coming out of the muffler sounds "rougher" than usual. So I don;t know if any of that is relevant. The car has 227,000 miles.
  7. #7 Re: Service Engine Soon: Grand Prix GT 3800: P0102 & P1133
    Feb 2013
    37.295091, -121.930053
    where step two?
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  8. #8 Re: Service Engine Soon: Grand Prix GT 3800: P0102 & P1133
    Aug 2011
    'Merica
    I would say you cat is clogged already
  9. #9 Re: Service Engine Soon: Grand Prix GT 3800: P0102 & P1133
    Quote Originally Posted by geeksweep View Post
    exhaust is probably rotting out on you. but the codes you have could make the car run poorly as well.
    used maf's are like 40 bucks or less at a junk yard, the o2 cost around 30 to 40 new. if a pig tail has gone bad, they cost about 10 bucks new.
    all easy stuff that should be addressed.
  10. #10 Re: Service Engine Soon: Grand Prix GT 3800: P0102 & P1133
    May 2013
    Mississippi
    Quote Originally Posted by Below Average Joe View Post
    why would you say that and can you put any kind of fluid in the system to unclog it, if thats the case?
  11. #11 Re: Service Engine Soon: Grand Prix GT 3800: P0102 & P1133
    once its clogged it need to be replaced.
    if it was clogged up the car would feel gutless, and the check engine light would flash when you floor it.
  12. #12 Re: Service Engine Soon: Grand Prix GT 3800: P0102 & P1133
    May 2013
    Mississippi
    hmmm ill try that out and let you know if i get a flash or not.
  13. #13 Re: Service Engine Soon: Grand Prix GT 3800: P0102 & P1133
    i wouldn't go beating on it with a maf and o2 code. fix that stuff. see how its running after.
  1. Replies: 3
    Last Post: 07-05-2012, 08:11 AM
  2. WTB - 1999 Grand Prix GT 3800 N/A Engine Harness
    By dbextreme in forum Wanted To Buy - Parts
    Last Post: 06-18-2012, 03:05 PM
  3. 98 Grand Prix GT 3800 159k on it but engine LOPES
    By Fritcr in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-26-2012, 11:53 AM
  4. Will a 04 grand prix 3800 engine fit into a 01 grand prix
    By jordan61488 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-24-2010, 01:01 AM
