My service engine soon light came on this morning so I went to Auto Zone for a free scan. The following codes came up on the computer and I have a more detailed print out that the guy gave me.
P0102:
(Man. absolute pressure)/BARO or MAF(Mass Air Flow) / VAF(Vane Air Flow) sensor condition.
Possible Causes:
1. Vaccuum hose off, cracked, or passage blocked.
2. Throttle body intake tube loose, off or cracked
3. Barometer/MAP defective
4. Vane Air Flow/Mass Air Flow sensor dirty or defective
P1133:
Heated Oxygen sensor - Bank 1 Sensor 1 (H02S11), insufficient switching
Possible Causes:
1. Failed H02S11 (Bank 1, Sensor 1) heater circuit.
2. H02S11 (Bank 1 Sensor 1) signal shorted the ECM ground
3. Improper oxygen supply to sensor - Check sensor connector and wires
The guy recommended to put some fuel cleaner but I don;t know if thats just a sales pitch. Would you guys have any recommendations??? How safe would it be to drive it for now? thanks again!
