Thread: Daytime Running Lights - 2007 GP base
Results 1 to 8 of 8
  1. #1 Daytime Running Lights - 2007 GP base
    Dec 2008
    Ontario, Canada
    Mine just up and quit. When they are working right they run using my low beam lights. The light sensor is working correctly. Replaced both bulbs, no change. High beam lights work fine. Going to manual doesn't change either. None of the part sources have a listing for a module. What gives? If there is a module, where might it be hiding? Any help would be appreciated.
  2. #2 Re: Daytime Running Lights - 2007 GP base
    Jan 2012
    Canada
    Just keep it like it is, drls suck
    Sent from my SGH-I747M using Tapatalk 2
    2001 GTP Special Edition - 3.29's built tranny, Coilovers with agx struts, 04+ seats, 18" Eagle 077's, Ported heads, ported blower, pacesetters, 3.4"
    2004 BMW 325CI with the sport package and the correct amount of pedals.
  3. #3 Re: Daytime Running Lights - 2007 GP base
    Because Firebird Govna47's Avatar
    May 2011
    Oak Ridge
    indeed they do, killer. It's the one thing about GMs that I hate
    2001 Pontiac Firebird 3.8L V6 - now accepting donations for new rear end - woot
    Why There's a Firebird Invading your Zone
    2001 Ferd Exploder Sport 4.0
  4. #4 Re: Daytime Running Lights - 2007 GP base
    Dec 2008
    Ontario, Canada
    It would be OK except I don't have any low beam at night. Highs work fine but piss people off.
  5. #5 Re: Daytime Running Lights - 2007 GP base
    Under the hood in the fuse box there is something called a HDM module, its basically a relay, should be number like 35????
    You can try replacing that, its a very likely cause for the low beam lights to stop working. The relay is not like any other inside the fuse box, so you can not swap it with another to test it as its "prongs" on the bottom are completly different.
    I think here in the USA, the relay is around 40 bucks. Also check any low beam light fuses.
  6. #6 Re: Daytime Running Lights - 2007 GP base
    Dec 2008
    Ontario, Canada
    TKS 5, will check and advise!!
  7. #7 Re: Daytime Running Lights - 2007 GP base
    Dec 2008
    Ontario, Canada
    Bullseye! TKS 5. It was exactly what and where you said. Couldn't get today at part sources so Dealer. $71 and tax later...... ouch. Thanks again
  8. #8 Re: Daytime Running Lights - 2007 GP base
    Anytime man.
    I knew they were kinda $$$ but it is what it is. Being in canada doesnt really help your cause lol.
  1. I need some help with my daytime running lights!!!!!!!!!
    By ReapeRx in forum Visual/Body Modifications
    Last Post: 07-25-2012, 06:03 PM
  2. Daytime Running Lights
    By joeringo11 in forum 04+ Specifics
    Last Post: 01-27-2012, 12:07 PM
  3. Daytime running lights
    By lucyboop in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-15-2011, 09:10 PM
  4. daytime running lights
    By 03renegade800 in forum General Tech Discussion
    Last Post: 08-16-2009, 07:06 PM
  5. A/C and Daytime running lights
    By hydrashok158 in forum General Tech Discussion
    Last Post: 08-14-2009, 09:06 AM
