Thread: a/c compressor labor
Results 1 to 20 of 28
  1. #1 a/c compressor labor
    GTX Level Member Jakegday's Avatar
    Nov 2008
    Fremont Nebraska
    Hello all. i know several of you have access to labor guides, so i was wondering if you could tell me how many hours it lists for replacing the a/c compressor on a 2001 grand prix? Thanks in advance
    Jake
    2001 GT: cat/ubend/resonator delete, zzp PLOG, custom intake, DHP pcm
  2. #2 Re: a/c compressor labor
    Do it yourself it's not to bad.
  3. #3 Re: a/c compressor labor
    Nov 2008
    Fremont Nebraska
    im going to. I just wanted an idea as to how much i will be saving
  4. #4 Re: a/c compressor labor
    Well it should only take you like an hour so I'm guessing the book says 2.
  5. #5 Re: a/c compressor labor
    GT Level Member Shiftingshaddow's Avatar
    KC
    i thought the hardest part was getting the line unbolted from the compressor cause its a tight squeeze. the bolt is between the two lines and they were kinda twisted funny so my extension and ratchet wouldn't fit. i didn't have as many tools then. i think i was using just a 10 mm wrench. not hard, just tedious. if i remember right, there was a super secret bolt for the compressor you could only feel, not see. but it wasn't hard to get off.
    2001 GTP Special Edition
    ZZP DP with Cat, Open Cone Intake, ZZP 1.0 PCM, 3.4 pulley, AL 104s, Rocker Panel Delete.....
  6. #6 Re: a/c compressor labor
    Nov 2008
    Fremont Nebraska
    yeah, i own the factory service manuals for this vehicle. the job doesnt look hard at all. 3 bolts in front, then a bracket in the rear with 1 bolt on the compressor. Figured the guides would have at least 3 hours considering the time needed to evacuate, then refill. My trusted shop is charging me $100 to evacuate, then leak test and refill with new oil after the job. does that sound reasonable to you guys?
  7. #7 Re: a/c compressor labor
    KC
    i dunno. i'm kinda red neck and if you know the compressor is bad then you just unhook the line and put the new one in and fill it. no need for a shop or leak tests. that is if you know that's what is leaking......or is it just bad as in won't turn on?
    the compressors do leak.
  8. #8 Re: a/c compressor labor
    GT Level Member 00grandprixgtp's Avatar
    Apr 2009
    Elkhart
    lol if u lived in Indiana I would evac and recharge for 20 bucks as long as u had the correct amount of Freon
    2.4Pulley, Ngk Tr7 plugs, Self tune, Methanol injection
    23.5 deg timing gen v,78mm billet tb , Poly dog mounts, Sd headers
    Zzp s2 intercooler ,UD wp pulley,is2cam,130# springs modded retainers
    P&P heads and lim built trans 3.29 gears harden parts 2500 stall shift kit
  9. #9 Re: a/c compressor labor
    Apr 2009
    Elkhart
    calls for 1.5 plus evac and recharge so say 3 hrs the shop im at calls for 1.5 to evac and recharge
  10. #10 Re: a/c compressor labor
    Banned
    Jan 2013
    Colorado
    Those bolts were a ***** to get out. Plus I couldn't get a socket to hold the tensioner so that was a ***** for the ****ing belt.
  11. #11 Re: a/c compressor labor
    Quote Originally Posted by camopaint0707 View Post
    Odd, this is a pretty straight forward item.
    Jack and support the pass side.
    Remove pass tire and splash shield
    Evac the system
    Remove 1 13mm or 15mm bolt holding the lines to compressor
    Remove 3 15mm nuts
    Remove two 15mm bolts from the backside
    Unhook electrical and slide out through pass wheel well.
    Keep in mind, that's only the compressor. You should be doing the seals, accumulator/drier and orifice tube each time you swap a compressor. The orifice was put in a less than good spot IMO.
  12. #12 Re: a/c compressor labor
    I had no problem swapping mine took about 20-30 min. But i had the front manifold out of the car at the time
  13. #13 Re: a/c compressor labor
    KC
    it should be really easy. nothing in the way. just gotta reach. hr tops. put your own frigerant in if you know there's not a leak problem. i say buy a new one, not used. if there is a leak probably find it yourself by feeling the lines. hope its not condensor. that aint fun and its a lot for a new one.
  14. #14 Re: a/c compressor labor
    Nov 2008
    Fremont Nebraska
    Quote Originally Posted by Shiftingshaddow View Post
    lol, id rather have the condenser go out then the evaporator. THAT would F my day right up!
    There is no leak, the a/c works great. Just makes a loud moan and horrible vibration at around 1300rpms. I just mentioned the leak test since its included with the service. and its a good idea to make sure you didnt pinch any o-rings before you load it up with $20-30 worth of refrigerant.
    Im really not too worried (famous last words) about any major issues. I plan taking it out through the passenger side wheel well. The manual also says to remove the lower air deflector for better access to the rear, but hopefully ill be able to skip that step
  15. #15 Re: a/c compressor labor
    Banned
    Jan 2013
    Colorado
    It was a ***** with everything in the way.
  16. #16 Re: a/c compressor labor
    KC
    really? could do everything underneath. there's nothing there in the way. put it on ramps. one of the easiest things I've done to one of these.
  17. #17 Re: a/c compressor labor
    He's a complainer.. speaking of..I might change his name. Complainer0707 Yup..off to do that.
  18. #18 Re: a/c compressor labor
    Nov 2008
    Fremont Nebraska
    yes, im also replacing the o-rings and accumulator. The orifice tube im still undecided on because of its location, and the compressor did not grenade. dont wanna create more potential for leaks if i dont have to either.
  19. #19 Re: a/c compressor labor
    I'm about to do mine and on the same fence. I get super icy air but the compressor bearings are giving up with only 219K on them.. what crap.
  20. #20 Re: a/c compressor labor
    Topeka, KS
    My compressor blew the seals 2 summers ago. I have a new on sitting in a box. Just not wanting to mess with the orifice tube. 5dollar part = alot of headaches! I need to go buy a new drier too.
  1. 4 way flasher switch broken, $370 for part + labor...
    By TomOfTarsus in forum General Tech Discussion
    Last Post: 11-06-2012, 07:54 AM
  2. Compressor
    By InfidelRebel in forum General Tech Discussion
    Last Post: 08-13-2009, 01:41 AM
  3. ac compressor help
    By kjohnson in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-25-2009, 02:28 PM
  4. AC Compressor
    By Willthesage in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-27-2009, 02:56 PM
  5. Happy Labor day
    By TDCRacing in forum Off Topic Discussion
    Last Post: 09-01-2008, 09:47 PM
