Thread: 99 gtp bearing noise
Results 1 to 6 of 6
  1. #1 99 gtp bearing noise
    Jul 2010
    Chicago
    I have a 99 GTP making a humming bearing noise while driving above maybe 20 mph. It is louder if I'm holding a speed whith light gas and when I let off the gas It sounds just like a bearing. I just did the driver side bearing a few months ago and this car had the cv axles done like a year ago. I've done bearings before and know to turn the wheel while driving to hear when it goes away or gets worse to determine the bearing bad but this Is wierd because when I'm on the highway it sounds like the right side bearing and if in doing like 40 or so off the highway it sounds like the driver side i just did. I'e read it could be like a differncial bearing or somthing?? Not sure on this one need some help.
  2. #2 Re: 99 gtp bearing noise
    jack the car up and grab the wheel and push and pull at the top of the tire, if it moves the bearing is bad.
  3. #3 Re: 99 gtp bearing noise
    Jul 2010
    Chicago
    No movement. What else could make noise like this?
  4. #4 Re: 99 gtp bearing noise
    bad tires can hum. try rotating the front tires to the back.
  5. #5 Re: 99 gtp bearing noise
    GT Level Member primem's Avatar
    Sep 2013
    Calgary, Alberta
    rule out the tires and wheel bearings first
    front or back? jack up the front end grasp the coil spring when the tires are in motion. a bad bearing will transfer into the coil spring.
    tire noise from irregularly worn tires; the tires usually have a feather edge, saw tooth pattern You should be able to see and feel this when running you hand over the tire. When the coil springs sag, the toe setting move more negative and wear the inside edge as the tire scrubs.
  6. #6 Re: 99 gtp bearing noise
    yup, all that too.^^^^^^
  1. Bearing noise
    By buickman104 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-29-2012, 02:15 PM
  2. Got a new noise. Might be transmission noise vid included.
    By buickman104 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-02-2012, 05:51 PM
  3. Low speed Wheel Bearing Noise? -97 GTP
    By 3R1CD4V15 in forum Brakes/Suspension/Chassis
    Last Post: 04-27-2012, 04:11 PM
  4. maybe bad bearing?
    By mvp2765 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-12-2009, 08:26 AM
  5. brand new wheel bearing, same old noise
    By bonerjamz03 in forum Brakes/Suspension/Chassis
    Last Post: 07-16-2009, 09:09 PM
