Thread: hot ac when engine temp gets hot
Results 1 to 5 of 5
  1. #1 hot ac when engine temp gets hot
    GT Level Member Shiftingshaddow's Avatar
    KC
    When its above 90 or so at idle the car will climb up to 210. I've had two different thermostats in it and it happened with both. New 180 and the stock 195. My other two gtp's never did this unless the coolant was low. This one doesn't leak at all though. the fans work cause they come on when I shut the car off (ZZP PCM). No air in the system. Coolant has been more or less changed. maybe there's too much water in it (after all the different maintenance and leak fixing)? So that's sorta issue number one. Issue two is that on occasion when it gets that hot the AC starts blowing hot air. How are the two connected?
    2001 GTP Special Edition
    ZZP DP with Cat, Open Cone Intake, ZZP 1.0 PCM, 3.4 pulley, AL 104s, Rocker Panel Delete.....
  2. #2 Re: hot ac when engine temp gets hot
    It might be that the gauge doesnt always tell the true temp, a scan gauge might throw out a different number.
    Maybe your freon is a little low for the reason the AC sometimes blows hot.
  3. #3 Re: hot ac when engine temp gets hot
    Never Never Land
    In my experience the factory analog gauge is worthless on 97-03 GP's. When my analog gauge says ~110* my aero says ~80
  4. #4 Re: hot ac when engine temp gets hot
    KC
    oh, sorry. just saw how that might have read. when the car's temp gets up to 210 the ac sometimes blows hot air. the temp outside has nothing to do with it unless it has just been coincidence. when i'm rolling along the ac is cold and gets too cold sometimes. and I just remembered the low coolant light came on once at 210 but the coolant is full.
  5. #5 Re: hot ac when engine temp gets hot
    Dec 2012
    Where 4T65E's were born
    Well if you're not moving and/or the cooling fans are not on, there is not much air moving past the condenser, so you will not get much cooling.
    The 3800 climbing up to 210 in 90° city traffic is perfectly normal. I put a 180° t-stat in my car as well just because I didn't want it running that high. No issues, but it was just my opinion.
    Oh and also, my analog gauge on my 02 is very accurate. Right as it's on the 200° line, my scan tool says 200° F. The increments on the gauge do NOT indicate actual increments, though.
    Sold.
  1. Engine Temp Issue
    By dpzelenak in forum 3.1L V6 (LHO/LG8)
    Last Post: 02-15-2016, 01:08 AM
  2. Engine Temp Gauge
    By Phil318 in forum General Tech Discussion
    Last Post: 11-12-2011, 02:54 PM
  3. Engine Temp Fluctuation
    By clintbaum in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-10-2011, 08:04 PM
  4. Weird engine temp problem
    By Rivmage in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-08-2011, 06:59 AM
  5. Engine temp question
    By toolguy in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-23-2009, 09:42 AM
