Thread: Gen III or Gen V...? I'm in the middle and need advise
Results 21 to 40 of 43
  1. #21 Re: Gen III or Gen V...? I'm in the middle and need advise
    I did but depends on your TB...
  2. #22 Re: Gen III or Gen V...? I'm in the middle and need advise
    I Write E85 Stickies Frosty's Avatar
    Apr 2011
    South Dakota
    Honestly the ic makes the gen3 a better option performance wise but the genV will fit on that i/c and make more power..... idk. Personally I dont like the gen3 blowers anymore so I would just get a genV and get a new core.
    "Lets just throw more boost at it and see what happens" -Frosty
    The Defacto Guide to tuning your car for E85. Read it and learn.
    I love Decker<3
  3. #23 Re: Gen III or Gen V...? I'm in the middle and need advise
    Quote Originally Posted by frosty View Post
    What???
  4. #24 Re: Gen III or Gen V...? I'm in the middle and need advise
    It's been shown and proven that a Gen V will sit on most Gen 3 cores and still work well. Sure there's an area that gets blocked, but the cooling benefit appears to be solid.
  5. #25 Re: Gen III or Gen V...? I'm in the middle and need advise
    Bill, didn the test show there was so little difference in the cores affect in regards to the blocked area that it was almost nothing? I need to find that test again. Because, iirc, they compared the genV core to the gen III core with a genV blower on both and there was almost no difference at all in regards to performance...
  6. #26 Re: Gen III or Gen V...? I'm in the middle and need advise
    May 2012
    Albuquerque, NM
    So, if I can trade the Gen 3 core for a Gen5 core for little cost it "may" be worth it but.....not more than $50-$100? I'll probably stick with the Gen 3 core with a Gen 5 blower. I'd love to see the study though, seems interested.
  7. #27 Re: Gen III or Gen V...? I'm in the middle and need advise
    May 2012
    Albuquerque, NM
    Quote Originally Posted by gtpsleeper View Post
    N* and LQ4? I know ZZP sells a downward angled mount, is that what I need?
  8. #28 Re: Gen III or Gen V...? I'm in the middle and need advise
    There were also guys that modified the Gen 3 core to fit a Gen V better.
  9. #29 Re: Gen III or Gen V...? I'm in the middle and need advise
    May 2008
    Schuyler, NE
    The worlds fastest M90 FWD w-body used a Gen III IC Core with a Gen V blower.
  10. #30 Re: Gen III or Gen V...? I'm in the middle and need advise
    May 2012
    Albuquerque, NM
    So, it's not a big deal at all then. I see how small of an issue it is now!
  11. #31 Re: Gen III or Gen V...? I'm in the middle and need advise
    pretty much what were saying ^^^^
  12. #32 Re: Gen III or Gen V...? I'm in the middle and need advise
    Donating Users Kejross's Avatar
    Feb 2010
    Oklahoma City, OK
    I was always of the understanding that a hogged out gen 3 was basically identical to a stock gen V. If the inlet has been worked on that gen 3 I would use that. But inlet size really isn't gonna be a big issue when you mate a stock l67 TB up cause that will be the limiting factor unless your going with a N*. Also nobody has mentioned the added cost of a TB adapter if you pick a gen V which adds anywhere from $50-100 to the cost of the swap.
    SOLD-98 4dr GTP, l32 Swapped, IS2 heads, IS3 cam, S2 intercooler, S3 FMHE, E85, 65# inj, N* TB w/LQ4, OBX Headers, Borla catback, 3.0 zzp mps, lc-1 wideband, HP Tuners, PRJ wires, FWI, Lowered. 04 GTO M6, 07 Grand Prix LS4 powered GXP. 98 V6 GMC SWB, exhaust, custom intake. 09 HHR (Wifes)
  13. #33 Re: Gen III or Gen V...? I'm in the middle and need advise
    Quote Originally Posted by Kejross View Post
    wrongo
  14. #34 Re: Gen III or Gen V...? I'm in the middle and need advise
    Feb 2010
    Oklahoma City, OK
    wrongo
    So a hogged out gen 3 90 cubic inch blower is how much less efficient than a 90 cubic inch gen V? Porting a gen V has shown minimal to no gains, while porting a gen 3 has shown measurable gains. And if they start off only 20hp appart in stock form I don't see how they could be THAT far appart once gen 3 is ported. I have heard a bit about outlet temps still being a bit higher with the gen 3 though if that's what your referring to? Maybe you could enlighten us all a little with some facts instead of just saying that's wrong???
  15. #35 Re: Gen III or Gen V...? I'm in the middle and need advise
    You dont have to be condescending about it, just simply ask... When you say "I have heard a bit about outlet temps still being a bit higher with the gen 3 though" makes me wonder how its that confusing to you?
    "hogging out" an inefficient 90 cubic inch blower does not necessarily make it just as good as another more efficient 90 cubic inch blower. The inlet/rotor design of the genV is more efficient and will always push more, cooler air than even the best ported genIIIs (which is why most have to pulley up when switching). With a simple, mostly stock setup, the added efficiency wont be as noticeable. But, when you get down to sub 3.0s, thats where the added efficiency shows the most. Do I have any measured data on that? Not off hand, but I have experience in the switch from a well ported genIII to a genV.... Huge difference...
    Also...
    The series 3 makes 20 more hp than the series 2. The series 3 has the genV and the series 2 has the genIII. The genV must be 20hp more efficient than the genIII.
    ^^^^ flawed logic... you cant just say 2 blowers are "20hp apart" simply by the power output of the engine they are on.
  16. #36 Re: Gen III or Gen V...? I'm in the middle and need advise
    The Boss Iceman6669's Avatar
    Jun 2011
    This is very true... As a matter of fact MOST of the higher HP blower builds used a GenV blower and a GenIII core.
    2011 F-150 Yote powered
  17. #37 Re: Gen III or Gen V...? I'm in the middle and need advise
    May 2012
    Albuquerque, NM
    So which gaskets do I need then? Gen 3 or 5?
  18. #38 Re: Gen III or Gen V...? I'm in the middle and need advise
    You can just use rtv.
  19. #39 Re: Gen III or Gen V...? I'm in the middle and need advise
    May 2012
    Albuquerque, NM
    Sounds even better! Thanks
  20. #40 Re: Gen III or Gen V...? I'm in the middle and need advise
    Apr 2011
    South Dakota
    I had a cnc ported fully built gen 3.... when I swapped for a genV I still had to pully up two sizes. The seat of the pants dyno also approved.
    Not to mention how freakishly loud a genv is.
    I love Decker<3
  1. 04 GP Temp gauge gets 1 notch over the middle? also loss of acceleration?
    By Joseph27705 in forum General Grand Prix Discussion
    Last Post: 07-08-2012, 10:10 AM
  2. middle east wi people
    By Hawkman in forum Midwest
    Last Post: 03-14-2012, 06:00 PM
  3. The display in the middle on a 1998 GTP
    By shawnz90 in forum Audio, Security & Visual Electronics
    Last Post: 10-23-2010, 10:14 PM
  4. YAY middle class F*CKED again !!
    By 16MustangVet in forum Off Topic Discussion
    Last Post: 09-15-2010, 01:07 PM
  5. Transmission Coolers for the Middle East
    By Panzer4 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-06-2009, 07:49 PM
