Thread: torque specs LIM
Results 1 to 5 of 5
  1. #1 torque specs LIM
    Donating Users blowfishRus6's Avatar
    g.a.
    what are the torque specs for the lower intake manifold and the supercharger??? im finally changing out my gaskets this weekend and i need to know. is it different for the series III?? i should have a hanes by then but just incase im asking.
    is there anything i should be conserned about or things i need to look out for when changing out my gaskets???
    and i got the gm gaskets
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  2. #2 Re: torque specs LIM
    I live here. UR LOSN's Avatar
    Rockford, IL
    Here is what you are looking for :
    clicky
    when changing it out....the minute you lift your LIM off the heads...coolant will be able to leak into the lifter valley. be prepared with paper towels... and have filter and fluids to do an oil change afterward.
    the coolant will leak into it no matter what, as there is a low spot in the LIM coolant passage.
    It is really easy to do. also make sue you have all the bolts out before prying up on the LIM...there are some "hidden" ones.... this also goes for the SC. there is one behind the snout.
    Good luck!! there is also a How To on this as well!!!
  3. #3 Re: torque specs LIM
    g.a.
    awesome!! thanks man.
    also can anyone find the video of the LIM and rocker install that someone did. it was very discriptive and a nice step by step. about 30 mins long. i cant seem to find it.
    its slow.
  4. #4 Re: torque specs LIM
    Barksdale AFB, LA
    While you're scraping away the old gasket material, make sure to lay down paper towels or shop towels to keep anything from dropping in. Also stuff all the opening in the heads to keep them free from debris. Here is an example from my gasket install:
    (this is when were done already done with the head on the left
    2009 Subaru Impreza WRX STI
  5. #5 Re: torque specs LIM
    g.a.
    good sujection. thanks man
    its slow.
  1. List of Torque specs
    By Andrew_99GTP in forum General Tech Discussion
    Last Post: 05-29-2020, 08:04 PM
  2. i need torque specs
    By MTXGTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-20-2008, 12:14 PM
  3. Looking For Some Torque Specs.
    By stlmo_gtp in forum General Tech Discussion
    Last Post: 07-10-2008, 02:58 PM
  4. need torque specs for...
    Last Post: 04-17-2008, 12:16 AM
  5. Torque specs
    By kstanko in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-31-2008, 12:47 PM
