Thread: Engine Ticking????
Page 1 of 4 123 ... LastLast
Results 1 to 20 of 77
  1. #1 Engine Ticking????
    GT Level Member 2FASTGTP's Avatar
    Apr 2012
    Indiana
    Ok so I have a 98 Grand Prix GTP with 98k miles. It has a clicking noise coming from the conical shaped part of the engine (to the left of the engine) Not sure if thats the supercharger or what. It kind of sounds like a can being kicked around. It disappears upon the slightest acceleration. What could it be? Is it a DIY kind of thing?
  2. #2 Re: Engine Ticking????
    Johnstown, NY
    That would be the supercharger coupler. It's about $50 to fix. You'll need a coupler from zzp, wbodystore, or 3800 performance, 2-3 bottles of Gm supercharger oil, an empty squirt bottle, 10mm socket, and I believe its a torx head plug on the conical section in front. Diy would probably take an hour? Not a bad job at all.
    Simply put, you take the snout off, replace a plastic piece, put the snout back on, and fill with the supercharger oil.
  3. #3 Re: Engine Ticking????
    That is your supercharger. The coupler needs replaced.
  4. #4 Re: Engine Ticking????
    Apr 2012
    Indiana
    Nevermind, I figured that part out, but how do you get the belts off? I watched a Youtube video and he said that you have to do that before anything. Sorry, I'm only 16 so new to the mechanics of cars haha
  5. #5 Re: Engine Ticking????
    GT Level Member penright's Avatar
    Mar 2013
    United States
    Quote Originally Posted by 2FASTGTP View Post
    Don't be sorry, I am glad to hear you are trying. PM me and I will give you my contact info. I am by far not an expert, but I did mess with cars in my youth. My first car was a 67 Mustang not be cause it was cool, they were just old cars. I bought it when I was 15 and my first project was a valve job. Of course back then they did not have the internet, youtube, or such. Just like you I tore it down and did my best to put it back together. Now I am not old enough to walk to school up hill both ways in the snow, the hill was just one way. :-)
    Just let me encourage you to keep asking questions and keep trying.
    07 Grand Prix GXP (My Daily Driver and future toy) (120,000+)
    97 Grand Prix GT (Project Car) (178,000+)
    02 Mustang Convertible (Wife's Toy) (75,000+)
    17 Honda Civic (Wife's Daily Driver)
  6. #6 Re: Engine Ticking????
    Apr 2012
    Indiana
    Alright so the coupler itself is only like 27 bucks. So how would I drain the current oil before taking the snout off?
  7. #7 Re: Engine Ticking????
    Use an old sprayer from a spray bottle
  8. #8 Re: Engine Ticking????
    15mm wrench on the tensioner
  9. #9 Re: Engine Ticking????
    Apr 2012
    Indiana
    Alright, thanks man!
  10. #10 Re: Engine Ticking????
    Apr 2012
    Indiana
    Ok so this supercharger oil: ACDelco Supercharger Oil 2-4OZ Bottles : Amazon.com : Automotive with this coupler, ZZPerformance - Supercharger Coupler #ZZ-SCCPLR,, install and i should be good?
  11. #11 Re: Engine Ticking????
    Apr 2012
    Indiana
    Theres also this one, $15 cheaper Eaton - EATON Replacement Coupler #ETN-30858
  12. #12 Re: Engine Ticking????
    only buy a green coupler, the black ones are stock replacement and dont last as long.
  13. #13 Re: Engine Ticking????
    try your local dealership, for what ever reason some states the sc oil is like 10 bucks and then here in NJ its 20 a bottle. looking on line you should be able to find it for less then that link.
  14. #14 Re: Engine Ticking????
    Seal the snout with anaerobic sealer
  15. #15 Re: Engine Ticking????
    Apr 2012
    Indiana
    such as blue loctite?
  16. #16 Re: Engine Ticking????
    use "anaerobic sealer" to seal the snout back to the case. no lock tight is needed.
  17. #17 Re: Engine Ticking????
    Only place I've found local that carries it is NAPA
  18. #18 Re: Engine Ticking????
    GTX Level Member Neil98gt's Avatar
    May 2011
    Kansas city
    You'll want gloves too probably.... supercharger oil is the most foul smell you will ever encounter.
    98 GT 2dr 116k, Sold
    07 Lexus ES350 Obsidian Black. Premium Plus package, sold
    2013 Hyundai Elantra GT
    2002 Grand Prix GT 4dr
  19. #19 Re: Engine Ticking????
    GT Level Member JaredR215's Avatar
    Jul 2011
    Cheyenne
    When you buy the ZZP couple you can get a kit to go with it that will have everything you need. It's a good way to go if you don't have the other things. Comes with a big syringe and hose to get the old oil out and comes with the sealant needed when putting it back together.
    Heres what I learned from doing mine
    WEAR GLOVES!!!!!! The old oil smells terrible.
    Get as much of the oil out as you can. I just put mine in a soda bottle
    when you go to take off the snout, be sure to put some rags under it to catch any oil.
    K&N Cold Air, ZZP Wires, ZZP 3" with hi-flo, Catback, ZZP 1.0 PCM., 180*, AL605's, 3.5 MPSStill fighting KR
  20. #20 Re: Engine Ticking????
    Quote Originally Posted by JaredR215 View Post
    what hes said^^^^^ i laid rags under the snout and down the side of the lim, and stuffed them down the top of lim and water pump, then as soon as it was off i sprayed it all down with brake cleaner, gears and all used said rags to mop up, then re sprayed and wiped it up again.
    and wear some latex gloves, doubling up is a good idea too cause this old oil is worse than a dirty whore lol
  1. ticking noise from engine
    By sca555 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-23-2011, 05:53 AM
  2. Engine Ticking
    By 2000gpgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-08-2011, 12:49 AM
  3. Engine ticking sound
    By zildjian102 in forum General Tech Discussion
    Last Post: 07-30-2010, 12:24 AM
  4. Ticking in the engine....
    By fortune4you in forum 3.1L V6 (LHO/LG8)
    Last Post: 03-01-2010, 09:59 AM
  5. i need help! engine ticking?? 3800
    By a.caldwell11 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-06-2009, 03:45 PM
