Thread: Overheating issue please help
Results 1 to 7 of 7
  1. #1 Re: Overheating issue please help
    GTP Level Member AjL227's Avatar
    IL
    How many miles are on the vehicle? Remove the accessory belt and spin the water pump by hand, can you feel side to side play? There may be a chance replacing the water pump at the same time wouldn't be a bad idea.
    I just changed my cousin's water pump/heater hose elbows on his 07 GT with 107k miles, today. It was the original pump which straight up seized yesterday and threw/jammed the belt between the oil filter and crank pulley.
    You could easily feel just how worn out the bearing was.
    I haven't heard any issues regarding the newly released aluminum heater hose units.
    Now on the other hand, some SII engine's had the horizontal bolt / 140 amp alternator bracket that it itself installed into the water pump inlet / timing cover and only used an elbow for the coolant coming out of the intake manifold.
    If you weren't gentle, those would break off in the timing cover, condemning the entire alternator bracket to the scrap yard.
    '04 CompG "WS6"
    '00 2.5RS "GM6"
  2. #2 Re: Overheating issue please help
    Oct 2012
    London ON
    Quote Originally Posted by AjL227 View Post
    Yep it was the water pump
  1. 2007 Base overheating Issue
    By bdkruse in forum Introductions/Noob Questions
    Last Post: 02-04-2013, 10:10 AM
  2. Overheating issue
    By Below Average Joe in forum General Tech Discussion
    Last Post: 11-13-2011, 11:42 PM
  3. overheating issue
    By alreadytooken in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-29-2011, 10:28 PM
  4. 96 grand prix overheating issue
    By Nuzzget in forum 3.1L V6 (LHO/LG8)
    Last Post: 07-10-2009, 12:37 AM
  5. overheating issue
    By doc7000 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-26-2008, 01:18 AM
