Thread: Aluminum cradles FTL
Page 2 of 2 FirstFirst 12
Results 21 to 33 of 33
  1. #21 Re: Aluminum cradles FTL
    SE Level Member alacran's Avatar
    Apr 2008
    Chicago, IL
    Quote Originally Posted by Blown97 View Post
    Interesting!! I've never been a fan of aluminum frame parts, but I haven't heard of a cradle cracking. Sorry for your luck!!
    Street Wolf, You got an idea?
    when first came out the police impalas were breaking them but i believe it was in a different spot.
    Where did you get this one from?
  2. #22 Re: Aluminum cradles FTL
    Barksdale AFB, LA
    Quote Originally Posted by alacran View Post
    Talking to me? It's the stock one in my 2004 Impala LS.
    I did the temp fix today. Not pretty but it works. In the first picture here, you can see the stock hole to the right I used to drill the first hole, and I had to drill the hole on the left and adjust it's angle with my dremel to be able to drill straight up for the second hole:
    Here you can see the two bolts. 3/8" bolts, 9/16" heads, and I forget the size of the washers. The holes are exactly the size of the threads, so there is no play around them at all. Thanks to my Dremel and its 90* attachment.
    I need to shorten the bolts about 1/16"-1/8". They hit the cross member above and that's why the crack isn't completely closed. I didn't have access to a good enough vice nor the time to do it tonight. I can take these back out easily, so I will get it done eventually.
    2009 Subaru Impreza WRX STI
  3. #23 Re: Aluminum cradles FTL
    Oklahoma
    Excellent information Sabre. Thank you for taking the time to do all that.
  4. #24 Re: Aluminum cradles FTL
    SE Level Member Arkanzan Wheeler's Avatar
    Apr 2008
    Quote Originally Posted by Sabrewings View Post
    Pictures say it all. Stress fracture (no impact did this):
    You do not think this damage had ANYTHING to do with it?
    I want to still do this to my car but I will get some added welds done to it first since this looks like a weak point, accident or not...
    2000 Daytona 500 Edition
  5. #25 Re: Aluminum cradles FTL
    Barksdale AFB, LA
    All Impalas/Montes have the ends of the front cradle support looking like that. Never understood why, but most of them have "tape" all over it to cover it. Years ago I started to peel it away and that's why you can see it. I didn't hit anything there.
  6. #26 Re: Aluminum cradles FTL
    TDCRacing
    Guest
    Welds are always suppose to be stronger than metal.If anything it should have cracked besides the weld. but thats besides the point.
  7. #27 Re: Aluminum cradles FTL
    Barksdale AFB, LA
    Quote Originally Posted by TDCRacing View Post
    Depends on how it's welded. Aluminum is difficult to weld properly because it can become brittle. If any impurities get in while welding, it just gets worse. Tig welding is the best way to do it, but GM probably cheaped out since it can be expensive.
  8. #28 Re: Aluminum cradles FTL
    Oct 2008
    Michigan
    I have seen many of these cradles. I guarentee you that damage above is what broke the welds. But the welds shouldn't have broke, the aluminum should've bent so the weld was weak. If anyone else drives your car they could've hit a curb and not said anything.
  9. #29 Re: Aluminum cradles FTL
    Apr 2008
    This is the part that looks like an accident:
  10. #30 Re: Aluminum cradles FTL
    Barksdale AFB, LA
    Seeing how that's been there since I bought the car four years ago, and this just showed up in the last month I don't see it being possible... Like fast98 said it's probably bad welds that cracked open, since they shouldn't have cracked at all.
  11. #31 Re: Aluminum cradles FTL
    I live here. UR LOSN's Avatar
    Rockford, IL
    GM uses an automated assembly line..... they might have had a bad welder. its possible?
  12. #32 Re: Aluminum cradles FTL
    GrandPrix Junkie FastKatt's Avatar
    Feb 2008
    Rkrd, IL
    Mine looks fine, and much cleaner than yours
    No trees were destroyed for this message.
    However, a great number of pixels were extremely inconvenienced.
    2004 Grand Prix Comp-G GTP Mod List - MySpace
  13. #33 Re: Aluminum cradles FTL
    Barksdale AFB, LA
    Quote Originally Posted by FastKatt View Post
  1. Aluminum oil pan
    By quiksilvergt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-26-2008, 12:45 PM
  2. ZZP aluminum heads
    By Sabrewings in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-15-2008, 08:28 PM
  3. My new aluminum motor mounts
    Last Post: 01-24-2008, 10:04 PM
