Thread: 06 gxp headlight problem
Results 1 to 8 of 8
  1. #1 06 gxp headlight problem
    May 2013
    Suffolk Va
    At random my headlights will turn off and I cant turn them on, my driving lights work and all other exterior lights work. I try the switch(as I have the automatic lights) and get nothing, it only happens after dark but if I turn the car off for 20-30 minutes they work again just fine.......any ideas as what I need to look for?
  2. #2 Re: 06 gxp headlight problem
    Pennsylvania
    Usually, when an 06+ loses headlight, it's the DRL relay... they're like $17 on ebay. But that's not, to my knowledge, an intermittent issue. The lights should be permanently off.
    So, I'm wondering if your DRL ambient light sensor (the bulb on the dash by the windshield) is faulty... whether there's a fuse issue, or whatever.
    Are you saying your headlights work fine in daylight?
  3. #3 Re: 06 gxp headlight problem
    GT Level Member Adidasdude1989's Avatar
    Jan 2012
    Sturgis, MI
    I hate DRLs, which is why i pulled the fuse on mine.
    Miles: 170-XXX
    Engine: 3.8L V6
    http://youtube.com/KBsVlog
  4. #4 Re: 06 gxp headlight problem
    I live here. DirtDog's Avatar
    Jun 2012
    04+ doesn't have a DRL fuse I've looked for mine so I could disable the DRL's
  5. #5 Re: 06 gxp headlight problem
    Check the fuses on the inside Marine
    04 Comp G.
  6. #6 Re: 06 gxp headlight problem
    GTP Level Member rperry435's Avatar
    Oct 2011
    MI
    Correction. 04 and 05-08 have different wiring diagrams. 05-08 have an HDM
    Sent from my SPH-L710 using Tapatalk 4 Beta
    '04 CompG - 3.6MPS - 104s - FWI - TOGS - w/14"SlimFans - SLP RR' s - 180HF Stat - TEP SK - Aluminum Oil Pan - 4thGen ZZP Wires - LS7 Lifters - AeroForce - AEM WB - HPTuners - FBSS Air Ride
    ASE & State Certified Auto Electrical Tech
  7. #7 Re: 06 gxp headlight problem
    Oct 2011
    MI
    04 have no DRL and no HDM. The way it should be. For some reason the douche engineers at gm decided to implement the HDM setup in the 05+ and besides taking out HID ballasts they fail often.
  8. #8 Re: 06 gxp headlight problem
    May 2013
    Suffolk Va
    Turns out it was the HDM thanks folks.
  1. Headlight problem
    By daytonshouse in forum Introductions/Noob Questions
    Last Post: 04-23-2012, 02:21 PM
  2. headlight problem HELP!!!!!
    By GTPSHAWTY in forum General Tech Discussion
    Last Post: 01-06-2012, 01:49 AM
  3. Headlight problem please help!!!!
    By nikkigpgt00 in forum General Tech Discussion
    Last Post: 02-07-2011, 09:30 AM
  4. BIG headlight problem, need help!!!
    By IndyGTP in forum General Tech Discussion
    Last Post: 11-05-2009, 03:16 PM
  5. headlight/fog problem
    By riceburner in forum Audio, Security & Visual Electronics
    Last Post: 01-08-2009, 09:29 PM
