Thread: Motor twisted in engine bay?
Results 1 to 10 of 10
  1. #1 Motor twisted in engine bay?
    GT Level Member DaytonaGTP500's Avatar
    May 2012
    Iowa
    Hey just trying to get some opinions on this. My motor looks noticeably twisted in the engine bay, like my dog bones aren't straight at all or anything. It looks like some one grabbed my engine and twisted the driverside forward and passenger side back and I do get a clunk when I shift into drive or reverse. So does this mean my craddle is hella twisted or motor mounts or what do you think? I talked to a shop and they said mounts but I dont always trust them guys. I have solid trans/engine mount and both Polly dogbones but I haven't installed them yet. Just tryin to get some other opinions because i was thinkin cradle at first but they said mounts n needless to say im a lil cornfused. All opinions welcome thankx
  2. #2 Re: Motor twisted in engine bay?
    change your motor and trans mounts, the ones under the engine. they be shot.
    i had the same problem.
    mine looked like this, and you can see why the engine is twisted a bit.
  3. #3 Re: Motor twisted in engine bay?
    GTX Level Member blackflag's Avatar
    Virginia
    looks like a piece of **** with bolts stuck in it
  4. #4 Re: Motor twisted in engine bay?
    thats what happens when you have a nasty valve cover leak, it runs to the mount, and eats it alive lol
    this is the rest of it.
  5. #5 Re: Motor twisted in engine bay?
    Virginia
    I have a minor valve cover leak! I should check mine out!
  6. #6 Re: Motor twisted in engine bay?
    if its hitting the ground its not minor, its a leak lol.
  7. #7 Re: Motor twisted in engine bay?
    Virginia
    Its more of a residue not major.... Yet I guess
  8. #8 Re: Motor twisted in engine bay?
    May 2012
    Iowa
    Good thing to know I jus replaced the valve covers because they was leaking like flipin crazy all over the place.. So jus replace the mount and all should go back to normal or can the motor actually be shifted with the mount bolts loose? Also do yall know anything about the zzp solid trans mount cuz I have one here now and idk it just seems weak to me. I can squeeze it and move it around a lil with my hands is this normal? I only ask because the other mount I got from napa is solid as crap
  9. #9 Re: Motor twisted in engine bay?
    yeah the new mounts will make the engine sit straight again.
    never used zzp anything. i'd use the one that feels the firmest.
  10. #10 Re: Motor twisted in engine bay?
    GTP Level Member Dee23's Avatar
    Jul 2012
    North Philly
    Funny, I just so happen to come across this thread and realized that I have somewhat of the same issue.. Just the another day i was looking into my engine bay and noticed that my motor is a lil off angle also. all my mounts are new but my two dog bone mounts are definately not parallel with each other.
    Cradle mounts are new and torqued to 118lbs so im not really sure whats causing the motor to be off center like that. Crazy, i didnt know this was a common problem
    Not your average grocery getter, but theres always at least two things on the list.... 10w-30 Castrol Titanium and Shell 91 premium mixed with a lil 100 octane racing gas......
  1. Spacing lower engine motor mount...
    By Iron Indian in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-25-2012, 03:51 PM
  2. Motor misfire. Check Engine Light
    By Egleone6 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-16-2010, 09:54 AM
  3. Motor Problems or Engine Swap?
    By sharp in forum General Tech Discussion
    Last Post: 06-20-2010, 06:16 PM
  4. pic of painted twisted star
    By mzendano in forum Tires & Wheels
    Last Post: 12-03-2008, 12:35 PM
