Thread: Door chime keeps ringing! Did I blow BCM?
Results 1 to 5 of 5
  1. #1 Door chime keeps ringing! Did I blow BCM?
    Cambridge, Ontario Canada
    I was just checking my foglight switch for power as my foglights are not coming on. I put the meters black on the black wire of the foglight plug, then with the red saw power in 2 different pins. I decided to jump one of those pins to see if the fogs would go on, at worst I figured a blown fuse & would try the other pin.
    Turns out that after the first pin didn't work
    a) I never got power in the foglight connector after that.
    b) Even worse, I now can't get the door chime to stop
    c) Radio reset
    d) HVAC controls didn't respond upon startup for 10 seconds or so.
    Did i blow the BCM or something?
    2005 E55 - stock
  2. #2 Re: Door chime keeps ringing! Did I blow BCM?
    Feb 2009
    flintnasty MI
    Unrelated, but my door chimes go off all the time because the trunk switch is janky.
  3. #3 Re: Door chime keeps ringing! Did I blow BCM?
    Nearly all the dash lights are out as well. DIC is ok & radio, climate control and cluster completely out
    2005 E55 - stock
  4. #4 Re: Door chime keeps ringing! Did I blow BCM?
    Fix the fuse you blew. and please.. get a schematic
  5. #5 Re: Door chime keeps ringing! Did I blow BCM?
    Rear Lamp Fuse 20A'er! Good Call
    2005 E55 - stock
  1. Door chime
    By yeacashgpgt2002 in forum General Tech Discussion
    Last Post: 07-09-2016, 02:18 PM
  2. HELP with the door open chime
    By asite57 in forum General Tech Discussion
    Last Post: 09-27-2012, 06:36 AM
  3. 97 gtp door chime
    By shawn3091 in forum General Tech Discussion
    Last Post: 09-12-2009, 01:48 PM
  4. Door chime keeps going off while driving
    By KoreyGTX in forum General Tech Discussion
    Last Post: 06-10-2009, 12:14 AM
  5. Door chime keeps going off while driving
    By KoreyGTX in forum Brakes/Suspension/Chassis
    Last Post: 06-09-2009, 03:51 PM
