Thread: 97 gtp door chime
Results 1 to 3 of 3
  1. #1 97 gtp door chime
    GT Level Member shawn3091's Avatar
    Jan 2009
    State College PA
    if i have the key in the ignition and open the door, the chime dings like normal, but when i take the key out with the door open it dings really fast and does not stop until the door is shut. what could be wrong? i have had it open with the key out and it will ramdomly stop dinging then start again, cant figure it out. might be related but when i put it into programing mode to try to program the keyfob i got to work on the car, it flashes a error code.
  2. #2 Re: 97 gtp door chime
    Jan 2009
    State College PA
    from reading around i think it sounds like a problem with my bcm, the local junkyard has a 97 gtp, what would i have to do to relearn it to work in my car, or would i just plug it in and it would work?
  3. #3 Re: 97 gtp door chime
    Jan 2009
    State College PA
    figured it out, i checked the wires going into the bcm and it ended up being the headlight/dimmer switch. it was not giving the bcm a + signal when the switch was turned to off.
  1. Door chime keeps going off while driving
    By KoreyGTX in forum General Tech Discussion
    Last Post: 06-10-2009, 12:14 AM
  2. Door chime keeps going off while driving
    By KoreyGTX in forum Brakes/Suspension/Chassis
    Last Post: 06-09-2009, 03:51 PM
  3. Annoying Door Chime
    By gpgt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-10-2009, 07:54 PM
  4. Door Chime/Speaker Problems
    By JBmiddy23 in forum General Tech Discussion
    Last Post: 12-20-2008, 10:46 AM
  5. Disabling the Door Chime?
    By Abrasive in forum General Tech Discussion
    Last Post: 03-01-2008, 03:41 PM
