The other little square box is the antenna/rieceiver. If the used car lot you purchased the car from installed it, they should have infromed you it was installed in the car. If I remeber correctly, the yellow wire was spliced inline with the (usually yellow) wire from the start/run/ignition cuircut in the steering column.
