Still have your stock crank gear? Put that on and put the dot to dead top. This should put the crank key at around 2 o'clock. Put the 0 labeled tooth of the new crank gear on and you'll find the 0 keyway and 0 tooth sit right were you need them to line up with teh dot on the cam gear.
