Thread: 2004 Grand Prix GT Slow Coolant Leak SOMEHWERE
Results 1 to 17 of 17
  1. #1 2004 Grand Prix GT Slow Coolant Leak SOMEHWERE
    May 2013
    Kansas City
    Alright, first actual post, but I've lurked this thing for a while. I have a 2004 Grand Prix and I'm having a mysterious coolant leak somewhere. I can't figure out where though. I've checked through the topics on the forum with no help.
    -It's not the head gasket, I tested it (also no weird smoke or anything like that)
    -I changed the radiator hose's and that didn't fix it
    -there are no puddles or wet areas that I can feel or see (including in the car)
    -The way I know it's leaking or low, without constantly checking, is the "sloshing" sound that comes from behind the dash (sound like a fish tank sometimes) from when I start it in the morning, but it eventually goes away. I've been putting water in it for now since, coolant costs way more and it's gone through a few jugs in the past month or two.
    Anyways, again, every area that the leak could be from (according to threads on there) seems to not be it. If you guys could offer any help that'd be amazing. If not I'll just have to take it to a dealer mechanic and pay $100 or so to get it diagnosed. Thanks in advance.
  2. #2 Re: 2004 Grand Prix GT Slow Coolant Leak SOMEHWERE
    Intake gaskets.
    Its eating the coolant slowly.
  3. #3 Re: 2004 Grand Prix GT Slow Coolant Leak SOMEHWERE
    May 2013
    Kansas City
    Intake gaskets.
    How can I be certain on that or check it? The car doesn't overheat at all
  4. #4 Re: 2004 Grand Prix GT Slow Coolant Leak SOMEHWERE
    GT Level Member penright's Avatar
    Mar 2013
    United States
    Quote Originally Posted by GrandPrix666 View Post
    Have you had to add coolant? If so, how often?
    07 Grand Prix GXP (My Daily Driver and future toy) (120,000+)
    97 Grand Prix GT (Project Car) (178,000+)
    02 Mustang Convertible (Wife's Toy) (75,000+)
    17 Honda Civic (Wife's Daily Driver)
  5. #5 Re: 2004 Grand Prix GT Slow Coolant Leak SOMEHWERE
    Its a 2004 with the factory black plastic intake gaskets that fail, its a very common issue and with 120k you are well over do for a change on those gaskets.
    The new aluminum gaskets stop the the issue of losing coolant.
  6. #6 Re: 2004 Grand Prix GT Slow Coolant Leak SOMEHWERE
    GT Level Member thegipper's Avatar
    grafton, wi
    This. I would replace those intake gaskets even if they arn't the problem right now because eventually they will be. Also check the weep hole on the water pump (check for play in the water pump pulley also), check the two coolant elbows (may just want to replace them right away with aluminum ones as they will eventually fail too).
    Check coolant reservoir for any leaks, the return hose for the reservoir.
    Start there, you'll probably fix your problem.
    02 GT - HV3, 3800 Perf. Tuned, Plog, ER rockers, DP w/Magnaflow, CAI, 180* stat, Plugs/Wires, Poly Uppers, Driver mod.....
  7. #7 Re: 2004 Grand Prix GT Slow Coolant Leak SOMEHWERE
    GTP Level Member AjL227's Avatar
    IL
    I'd be surprised if he made it to 120k with the plastic intake gaskets.
    Mine is an L32, but I HAD to change them at 45k.
    OP, if you've never changed intake gaskets...now would be a good time.
    How's the water pump? Remove the pulley and turn it by hand. Does it free wheel long after you turn it?
    Replacing the coolant elbows with aluminum units would be more possible leaking plastic material taken out of consideration.
    '04 CompG "WS6"
    '00 2.5RS "GM6"
  8. #8 Re: 2004 Grand Prix GT Slow Coolant Leak SOMEHWERE
    Mar 2013
    United States
    Can I throw a theory out and see what you all think? As we all know, the intake gasket is a weak link. It was my understanding that they were recalled and the dealer used some sort of stop leak. You don't think when we change out the orange and flush we get rid of the "stop leak" ability?
    Out of three 3.8 and one 3.1, I have had two intake gaskets leaks.
    I bought 2 2002 Grand Prix with 20,000 about a year apart (one was early 02, and the other later 02).
    One was a 3.8GT and the other was the 3.1SE.
    Then I had a 99 3.8GT that had 70,000 and my daughter drove it through college, her husband traded off and I am not sure how many mile it had, but they had not problems, but I never touched the coolant in that car either for water pump or nothing.
    The 02 GT, I got rid of it around 240,000 and the only other coolant issues is about 4 water pumps and the plastic elbows.
    The other 02 SE3.1, I put a intake gasket on it about 60,000 and one water pump. It has about 240,000 and for a while I have been loosing coolant with no trace except for having to add some every now and then. Now I have some seeping between the block and intake. I bet it was going out the exhaust I was not seeing anything in the oil. I am getting ready to send it to the auction, I just bought a 07 GXP last week.
    My fourth Grand Prix is a 06 GT3.8. I bought it was about 55,000 now has 158,000. I have not had any leaks, except one water pump. I have flush it once.
    Then the 5th Grand Prix as mention is an 07 GXP just recently bought with 46,000 miles. Too new for any history yet.
  9. #9 Re: 2004 Grand Prix GT Slow Coolant Leak SOMEHWERE
    May 2013
    Kansas City
    So I got under the car to tell, again there was nothing visible on the top of the car as far as leaks go. When I got under the car I saw there was definitely a leak coming from somewhere because I could see the green coolant everywhere. I filled the reservoir with water to see if I could find it and found nothing.
    I've got to fill up the reservoir every week and a half/ 2 weeks. Any way I can a step by step on the intake gaskets or an estimated cost on replacing them? I checked the water pump and no issues.
  10. #10 Re: 2004 Grand Prix GT Slow Coolant Leak SOMEHWERE
    Mar 2013
    United States
    Antifreeze does not evaporate like water. Do you have access to air hose. If you could blow off all the puddles, then see where it comes back from. I think it goes without saying to be careful of moving parts if you do it while the car is running. Another options is rinsing it off good at the carwash and really if there is not any grease just a water hose will do it. Clear water will carry off the antifreeze, then evaporate leaving only the new antifreeze.
    As I said, my 02 GT leak for a while before the plastic elbow let go. I was adding about the same or once a month and I could get a whiff of antifreeze but could not find it. Also, it still could be the intake gasket, running to the bottom of the car. Watch real close between the intake and head. Also, it could be early enough that the leak is coming and going, even though you check once, look again at the water pump.
    With almost 600,000 miles in Grand Prixs, these are the only areas I have had issues with, not saying it can't be something else, just looking at the odds.
  11. #11 Re: 2004 Grand Prix GT Slow Coolant Leak SOMEHWERE
    GT Level Member GTX's Avatar
    Apr 2008
    Vallejo,Ca
    could be the coolant elbows, could be the intake gaskets....pressure test the cooling system
    COMP G
  12. #12 Re: 2004 Grand Prix GT Slow Coolant Leak SOMEHWERE
    While the plastic gaskets are a weak link, I've seen many achieve close to 200K and sometimes the gaskets still look good. However they are an issue and likely if you change them out etc, you'll clear up any issues you have going on.
  13. #13 Re: 2004 Grand Prix GT Slow Coolant Leak SOMEHWERE
    GTP Level Member BlackGT97's Avatar
    Jul 2011
    Michigan
    Dads monte lasted 305k without changing them
    1997 Grand prix GT Black Coupe- The beater
    1998 Grand prix GT Black coupe- Top swapped, XP cam
    2008 Grand prix Midnight blue- The slow but nice car
    1999 Chevrolet Silverado red ext. Cab
  14. #14 Re: 2004 Grand Prix GT Slow Coolant Leak SOMEHWERE
    GT Level Member Kilroy's Avatar
    Mar 2013
    Manitoba, Canada
    Isn't there a leak detection dye you can use, something like what is used to find A/C leaks?
  15. #15 Re: 2004 Grand Prix GT Slow Coolant Leak SOMEHWERE
    May 2013
    Kansas City
    I think I may just need to bite the bullet and take it in to a shop. I seriously can't find where the hell the leak is from. It seems to only leak, and slowly, when the car is moving.
  16. #16 Re: 2004 Grand Prix GT Slow Coolant Leak SOMEHWERE
    GT Level Member JaredR215's Avatar
    Jul 2011
    Cheyenne
    I just got my coolant leak cleared up in my 98 gtp. Here's what I learned from it.
    1. Trust what the guys on here have to say
    2. Use an inspection mirror to try and find the leak on the underside of things.
    Is there coolant being flung up onto your hood from your belt?
    start feeling around all of your pullies to find how "high" the leak is.
    My leak was a bad waterpump, so I had coolant dripping onto my crank. I could reach under the pump and find coolant. After that was cleared up, I then had an O-ring on a coolant elbow fail.
    Coolant leaks tend to be pretty simple fixes, just gotta find where it's coming from. Try what I listed above and let us know.
    K&N Cold Air, ZZP Wires, ZZP 3" with hi-flo, Catback, ZZP 1.0 PCM., 180*, AL605's, 3.5 MPSStill fighting KR
  17. #17 Re: 2004 Grand Prix GT Slow Coolant Leak SOMEHWERE
    Kansas
    Here is my suggestion like everyone else.
    Lower Intake Manifold gaskets with new revised aluminum gaskets. There is a write up on here how to do it at home with a basic socket set.
    While you are there you will have to change out coolant elbows which is also a known issue. Dorman has some newly revised aluminum elbows instead of plastic. Get yourself a set of those.
    Make sure you do an oil change right after you put the gaskets on. Some run it for a bit then replace the oil.... a bit as in couple of minutes.
    The way I see it you can spend ~$100 dollars now to be sure that your engine internals will be okay.
    If the leak is exterior... it will be cheaper than buying a whole new engine. I replaced mine at 80k, and they still looked fine slight deterioration... but I did it for a peace of mind.
  1. Coolant leak behind power steering box - 2000 Grand Prix V8
    By wcoughlin in forum Introductions/Noob Questions
    Last Post: 10-09-2012, 08:46 PM
  2. Power Steering Leak - 2004 Grand Prix GT
    By TomDaBomb2u in forum General Tech Discussion
    Last Post: 03-23-2012, 06:20 PM
  3. 2004 GT2 Coolant Leak on Passenger Side
    By apok in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-22-2011, 10:14 PM
  4. 2004 GT, Coolant leak
    By makenzie71 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-17-2011, 11:40 PM
  5. 93 Grand Prix stalling, running hot, coolant leak
    By thehollowaytape in forum 3.1L V6 (LHO/LG8)
    Last Post: 06-07-2011, 10:46 PM
