Thread: Grinding noise under the hood..
Results 1 to 5 of 5
  1. #1 Grinding noise under the hood..
    SE Level Member Akcalvinkid's Avatar
    Mar 2013
    Ocala FL
    So there's been this noise under my hood and it's annoying me.. I'm not sure what it is, I thought it was the coupler, so I replaced it, didnt do anything.. Then thought it was the alternator, so I replaced it, still didnt do anything..
    here is a video of the noise..
    Grinding noise - YouTube
    1998 Pontiac Grand Prix Pace Car Daytona 500 edition
  2. #2 Re: Grinding noise under the hood..
    St. Louis
    Could be the A/C compressor. Maybe try removing the belts and start it up breifly. If the noise is gone then you know its one of the pulleys.
  3. #3 Re: Grinding noise under the hood..
    Mar 2013
    Ocala FL
    Is it okay to start the car with both belts off? It won't hurt the car?
  4. #4 Re: Grinding noise under the hood..
    Kansas
    You can first remove the S/C belt. See if the noise goes away, if not remove the other one. Like previously stated do it for a very short time. If your problem still exists you have bigger issues.
  5. #5 Re: Grinding noise under the hood..
    If the car is cold, you can run the car for many minutes without the water pump running as it will take a little bit for it to heat up.
  1. Grinding noise when going 30 and up!
    By rbrown81 in forum General Tech Discussion
    Last Post: 11-06-2011, 08:43 PM
  2. Grinding Noise
    By EJOUIE in forum General Tech Discussion
    Last Post: 10-08-2011, 11:28 AM
  3. grinding noise
    By BoostnBlackGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-26-2011, 11:28 AM
  4. grinding noise.
    By BoostJunki3 in forum General Tech Discussion
    Last Post: 01-03-2011, 11:03 AM
  5. new grinding noise
    By offroadfury6 in forum Brakes/Suspension/Chassis
    Last Post: 08-12-2010, 08:07 AM
