Thread: Pulley upgrade and SD RAM AIR
Results 1 to 6 of 6
  1. #1 Pulley upgrade and SD RAM AIR
    Feb 2015
    california
    I am wanting to upgrade my supercharger pulley to a 3.0-3.4 What is something I should know before I do this? New belt needed? Will the smaller pulley put more stress on other parts and cause problems? Which size is recommended?
    Also I am wanting to get an SD RAM AIR HOOD. What is the going price for a paint job on the hood? Powder coating a good idea or bad idea? 3800Performance AmericanSportsCar and PFYC all sell this hood at different prices. Which would be the best or does it not matter? Any input on these questions would be appreciated. Thanks.
  2. #2 Re: Pulley upgrade and SD RAM AIR
    Feb 2013
    Missouri
    http://www.grandprixforums.net/threa...00-Powered-Car!!
    An SD hood is fiberglass so it can't be powdercoated. I picked mine up off of craigslist and have yet to paint it, so I can't help ya there.
  3. #3 Re: Pulley upgrade and SD RAM AIR
    Oct 2011
    Toledo, OH
    Get headers first. then read the ^^^ thread.
    7"
  4. #4 Re: Pulley upgrade and SD RAM AIR
    Rockers and headers and you should be able to run a 3.4 perfectly fine.
  5. #5 Re: Pulley upgrade and SD RAM AIR
    being your in the great stinking st of CA, go check your auto laws. you'll need a some expensive headers due to that carb BS over there. tog, or slp headers are carb compliant.
    and you'll need a tune.
    and my car had kr out the ass with 3.4 rockers and headers. till it was tuned.
  6. #6 Re: Pulley upgrade and SD RAM AIR
    May 2008
    Schuyler, NE
    Headers suck donkey balls.
  1. Pulley drop! ..Due for a fuel system upgrade?
    By 88formula in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-09-2013, 04:03 PM
  2. Pulley upgrade?
    By raverockstar in forum General Grand Prix Discussion
    Last Post: 02-14-2013, 06:23 AM
  3. Headlight and FogLight Upgrade (to upgrade to HID or not?) Please Help???
    By Michigan04GrandPrix in forum Visual/Body Modifications
    Last Post: 04-20-2012, 12:53 PM
  4. Tuning for a 3.5" pulley upgrade
    By mechguy in forum PCM Tuning
    Last Post: 01-24-2012, 04:44 AM
  5. PCM and Pulley upgrade
    By Whitehispanic in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-12-2008, 12:19 PM
