Thread: Charged ac still not cool
Results 1 to 9 of 9
  1. #1 Charged ac still not cool
    SE Level Member RICHEYSGTP's Avatar
    Oct 2012
    Indiana
    Ok wife said ac wasn't working in the car 04 gp so went and got some ac charge filled until it said I was in the green. Now it's still not even cool air
    Coming out and I see a little puddle of green oily liquid coming out under the front bumper. I can hear a small hiss
    But can't actually see where it's coming from but seams to be under or in front of radiator
    Any suggestions ?
  2. #2 Re: Charged ac still not cool
    GTP Level Member
    Apr 2012
    Las Vegas, Nv
    Go to a shop and have them do a proper AC job.
    GPONA #1 Cyber Bully
  3. #3 Re: Charged ac still not cool
    Feb 2013
    37.295091, -121.930053
    sounds like you have a cracked line.
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  4. #4 Re: Charged ac still not cool
    Sounds like a condenser.
  5. #5 Re: Charged ac still not cool
    GT Level Member 00grandprixgtp's Avatar
    Apr 2009
    Elkhart
    get a black light and start looking and or also a ac sniffer that all a shop will do is sniff it and look for the glow with a black light prob a condenser if I had to guess
    2.4Pulley, Ngk Tr7 plugs, Self tune, Methanol injection
    23.5 deg timing gen v,78mm billet tb , Poly dog mounts, Sd headers
    Zzp s2 intercooler ,UD wp pulley,is2cam,130# springs modded retainers
    P&P heads and lim built trans 3.29 gears harden parts 2500 stall shift kit
  6. #6 Re: Charged ac still not cool
    You have a leak in the system. The correct way to fix it is to replace the broken part, drier and orifice tube. Vacuum down the system to remove moisture/etc and ensure it's holding for at least 10 min. Then fill with the correct amount watching both high and low side pressures.
  7. #7 Re: Charged ac still not cool
    GTP Level Member Burbman's Avatar
    Dec 2008
    ****'s Creek
    Quote Originally Posted by BillBoost37
    Anyone know what the correct pressures are for an 01 3.8 n/a?
  8. #8 Re: Charged ac still not cool
    GT Level Member orange57's Avatar
    Aug 2012
    Chandler, AZ
    pressure should fall in to place if all components are in working order and the correct charge is weighed in. you can still showpressures within the allowable range with a low charge. refrigerant weight is more critical.
  9. #9 Re: Charged ac still not cool
    Dec 2008
    ****'s Creek
    OK thanks.
  1. twin charged?
    By Ifryrice in forum General Tech Discussion
    Last Post: 08-13-2012, 10:20 AM
  2. gt none super charged....
    By Jacob Turrentine in forum General Tech Discussion
    Last Post: 05-09-2012, 05:28 AM
  3. Turbo Charged GTP
    By RPM_INC in forum Turbo
    Last Post: 09-23-2008, 07:31 AM
  4. Super charged/non-super charged question
    By ohgreatone32 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-04-2008, 10:31 PM
  5. Dual Charged GTP
    By John_Shughart in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-28-2008, 12:31 PM
