Thread: Traction control light always off?
Results 1 to 4 of 4
  1. #1 Traction control light always off?
    May 2013
    United States
    Hey guys, dont 't know if this is a common problem with grand prixs or not but my "TRAC OFF" light is always on, even if i press the traction control button, nothing happens, anyone have a clue on what may be causing this??
  2. #2 Re: Traction control light always off?
    St. Louis
    Is your ABS light on as well? Usually this is an indication of a dirty/broken conenction at the wheel speed sensor or a bad wheel bearing, usually in the front.
  3. #3 Re: Traction control light always off?
    May 2013
    United States
    no abs light is not on
  4. #4 Re: Traction control light always off?
    Jul 2013
    Cranston, RI 02921
    I have the same problem with my 2003 GP-SE. Did anyone ever solve this? The Trac Off light is ON all the time and the trac button does nothing. My ABS and Engine lights are both off. I thought the passengers side hub was the problem so I replaced it. No change. I plugged a new wheel hub in on the drivers side (but didn't have a time to replace it yet). No change. I inspected the wires and added dilectric grease to the connectors.
  1. ABS, traction control light and no cruise control?
    By dirtdriver11 in forum Brakes/Suspension/Chassis
    Last Post: 07-30-2012, 10:19 PM
  2. ABS, traction control light and no cruise control?
    By dirtdriver11 in forum General Tech Discussion
    Last Post: 07-30-2012, 07:16 AM
  3. ABS, traction control light and no cruise control?
    By dirtdriver11 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-30-2012, 07:14 AM
  4. ABS and Traction Control Light on.
    By midrange in forum General Tech Discussion
    Last Post: 02-18-2012, 08:20 AM
  5. abs and traction control light on...why???
    By jtheripper211 in forum General Tech Discussion
    Last Post: 09-01-2009, 03:29 PM
