Thread: Grand Prix GTP ELECTRICAL ISSUE
Results 1 to 5 of 5
  1. #1 Re: Grand Prix GTP ELECTRICAL ISSUE
    GT Level Member GTX's Avatar
    Apr 2008
    Vallejo,Ca
    I've swapped multiple relays to the IGN1 slot with the same outcome....I have since swapped out the underhood fuse block, ignition switch, and the off chance the EBCM...all having the same issue
    now, i decided to give my ECT2000 a shot at this...and sure enough it began to beep at me a little below the fuse box, so i disconnected all connections to the junction block (not fuses and relays, but the 7mm bolt hold downs ) beeping stopped. plugged in the harness that controls IGN1 relay and the beeping returned...i have a short to ground in that harness...traced the "beep" to under the dash...unfortunately for me the harness disappears...i guess i need a wiring harness diagram or remove the dashboard itself...and that is a giant FML
    COMP G
  2. #2 Re: Grand Prix GTP ELECTRICAL ISSUE
    Apr 2019
    St. Charles
    did this vehicle have an aftermarket radio?
  1. 2004 Grand Prix Gt electrical issues
    By hydrashock in forum General Tech Discussion
    Last Post: 03-18-2013, 02:06 PM
  2. grand prix electrical problems
    By asite57 in forum General Tech Discussion
    Last Post: 08-25-2012, 08:26 AM
  3. 02 grand prix electrical question
    By sjb in forum General Grand Prix Discussion
    Last Post: 08-22-2012, 08:23 AM
  4. Electrical problem with 06' grand prix
    By nelliott in forum General Tech Discussion
    Last Post: 11-24-2009, 04:52 PM
  5. 98 Grand Prix Electrical problem
    By soulmonger in forum General Tech Discussion
    Last Post: 07-01-2009, 04:10 PM
