All of a sudden, it appears as if my power steering is leaking. I changed the fluid, I just pumped it out of the reservior and added new fluid. The level was a little bit over the Cold line, but not even halfway between hot and cold, so I figured it would be fine. I made sure the system was bled also. It looks like it's leaking from the driver side, here in the pictures below. I just drove the car so I'm waiting for it to drip on the ground again to confirm this is where it's leaking from. I'm just curious as to why it would leak from just changing the fluid?
I have oil leaking also, from the back of the engine. My front valve cover leaks a little bit (and drips onto the exhaust manifold) so I immediately thought of the rear valve cover gasket, but when I felt around behind the engine, it really wasn't oily, just greasy. I'm really hoping it's not the oil pan gasket, is there anything else I could check first? Pictures:
While I was investigating all of this, I checked the oil pressure sensor to see if that was leaking, and found that right above my lower motor mount, there's oil pooled in this bracket: (sorry I couldn't get a good picture of it)
Any help is appreciated.
