Thread: Racetronix fuel pump install problem
Results 1 to 9 of 9
  1. #1 Racetronix fuel pump install problem
    Apr 2011
    Vassar, Mi
    I bought a Racetronix pump and harness from PRJ and I was trying to install it tonight but it seems my car has had the fuel pump replaced with a non-factory basket. It has a "carter" sticker on the top of the module and the fuel pump is totally different. It does have a Walbro pump in it already too. What do I do? Should I try to get a factory FP module, can I modify what I have and make it work? Should I just put it back together and put it back in seeing as though the numbers on the Walbro that is already in it come up as a 255 replacement pump anyway....?
    1999 GTP Coupe ------ Comp Cam 76-802-9, 2.7" pulley, S2IC, N*, FWI, SD Headers, DHP Tune, Built trans (single 3.29s, 300m), Magnaflow Catback, 60#injectors, E85, MT ET Street DR's, Fbody brakes, PRJ pump/rails. 302whp/328ft-lbs.......12.41@110mph
  2. #2 Re: Racetronix fuel pump install problem
    May 2008
    Schuyler, NE
    It doesn't make sense that you have a 255 walbro in it already, and the racetronix doesn't fit..because that's a walbro 255 as well.
  3. #3 Re: Racetronix fuel pump install problem
    Apr 2011
    Vassar, Mi
    the racetronix is a drop in for the factory venturi setup, the carter replacement that was already in mine isnt a venturi style. Just went to the pick and pull and checked 3 different w- bodys, couldnt find one with a venturi. Were GTP's the only one that had one? I checked a 98 Riv w/supercharger, 99 3.1 Century and a 99 Olds Intrigue w/3.8 na
  4. #4 Re: Racetronix fuel pump install problem
    May 2008
    Schuyler, NE
    I don't know what all cars had them, but 97-00 GTP's should have them. And, the 01's with metal tanks should also have them. GT's didn't get venturi's to my knowledge.
    I believe Regal GS's are about the same way.
  5. #5 Re: Racetronix fuel pump install problem
    Apr 2011
    Vassar, Mi
    hmm.....I guess the stock pumps going back in it. I dont have time or money for this ****...
  6. #6 Re: Racetronix fuel pump install problem
    Ohio
    Only 97-00 gtps have venturi setups. No na cars have them... Except for 04+ Montes. They apparently have them regardless of na or l67
  7. #7 Re: Racetronix fuel pump install problem
    Apr 2011
    Vassar, Mi
    Morads got one listed on Ebay.....for $75 used....****ing crooks. I wont buy it from them just on principle. What a bunch of ****ing losers.
  8. #8 Re: Racetronix fuel pump install problem
    Jan 1970
    Maquoketa, Iowa
    Email them for a quote and tell them your from clubgp, they may go lower. Or just tell them you need a venturi style bottom half w/o the pump and see what they have.
  9. #9 Re: Racetronix fuel pump install problem
    May 2008
    Schuyler, NE
    No kidding...they jack up their prices on Ebay because they know people will pay it. Email them, and it will more than likely be cheaper.
  1. RaceTronix wrong pump
    By Beelzeboul in forum General Tech Discussion
    Last Post: 09-24-2012, 11:09 AM
  2. Need Help! ZZP fuel Pump install wtf?
    By Agentlongwood in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-19-2012, 10:02 AM
  3. Fuel pump install.
    By TDCRacing in forum How To Write-Ups/Tech Tips
    Last Post: 11-12-2011, 10:51 AM
  4. Racetronix Fuel pump canister install questions...
    By Iron Indian in forum General Tech Discussion
    Last Post: 05-18-2009, 12:11 AM
